OSD display on Relisys monitor 15" TH-561-RU
In the past few days, the OSD display panel on my monitor has started popping up. Sometimes it will drop out again, and sometimes I have to go to exit to get rid of it. But increasingly it is not responding, and stays on for several minutes, blocking the centre of the screen.
Anybody got a solution, please? The handbook doesn't help (and I am no techie, I'm afraid).
Thanks
  • 4 more comments
  • heilly Sep 11, 2008
    Thank you, amit_cis_sof, I will try this.
  • Anonymous Oct 11, 2008
    driver
    the OSD on my moniter appeared randomly and keeps scrolling through the options even if no buttons are being pressed and wont let me exit the menu
  • martyw123 Nov 27, 2008
    F-419 monitor started the osd adjustment menu randomly in the center of the screen. Stays on, goes off, comes back on for no reason. Changed monitors and seems to be specific only to my F-419. No viruses on PC that would cause this.
  • koshin Dec 12, 2008
    Same problem here.
    OSD appears randomly, with most cases set Brightness to maximum.
    I moved osd to the left bottom corner, to work, but problem is very anoying.
  • Anonymous Jan 10, 2009
    qsq
Please reinstall ur display driver i was getting same problem u can also download driver software
Posted on Sep 11, 2008
Lcd monitor working fine but the adjustment screen apears on my monitor in a small square enveloppe how can i restore system thanks in advanceDewulf Jan
I assume by "adjustment screen" you mean the OSD (On Screen Display). This is the box where the menus for adjusting the screen appear. If I'm correct, that means you have pushed the "menu" button on your LCD and need to push it again to turn the OSD off. If pushing it again does not solve the problem I would say it's time to have the LCD repaired. In many, but not all, that OSD goes off on it's own after a bit.
Mar 01, 2014 | Relisys TL565 15" LCD Monitor
Osd menu popping up ..how do I stop it
just to make sure we are talking about the same thing, when talking about the OSD (on-screen display) that normally refers to the monitor only, such as the menu to adjust horizontal positioning, or the mode (digital or analog) setting. Is that what you are talking about? If so, what does it say?<br /> <br /> Did this just start? Have you recently changed resolution settings? I note in your manual the following warning:<br /> <blockquote><font color="Navy">The On Screen Display manager also features pop-up<br /> warning messages for certain situations, such as if you<br /> attempt to set the monitor resolution outside the<br /> recommended range.</font></blockquote>It also says:<blockquote>Your monitor is optimized for 1024 X 768 @ 60 Hz. </blockquote>Are all cable connections secure?<br /><br />And if you right click on the Desktop &gt; Properties &gt; Settings, what is the resolution set to? 1024x768 it will be ok<br />
Aug 30, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
W2361vg
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
Aug 29, 2009 | LG L1915S 19" LCD Monitor
CANNOT REMOVE THE OSD MAIN MENU FROM MONITOR SCREEN
The problem of OSD Menus popping up automatically are usually caused due to a faulty switch in the Menu button which is getting switched on automatically.
This menu will not harm the computer but constant OSD menu will most probably lead to permanent damage to the pixels in the LCD screen plus it is a constant irritation to your eyes which are most precious.
This problem can be rectified by replacing the faulty menu switch. Hope this solves your problem Thanks.
Jul 23, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Acer AL511
Hi...there,
I thinks your OSD Setting time set to high... Open on screen display on your monitor, go to OSD Settings and look for OSD hold time and setting to 10 seconds. If that doesn't work...reset to Factory Resettings.
Jan 12, 2009 | Acer AL511 15" Flat Panel LCD Monitor
OSD LOCKOUT
1. Replaced the Micro switchs.
2. press the menu switch 15 to 20 secunds.
Nov 02, 2008 | Computers & Internet
Whereabouts and meaning of OSD
OSD stands for On Screen Display. You get to it by pressing the Menu button on the front of your monitor.
Here's a link to making adjustments...and unlocking the OSD:
HP f1703
Oct 18, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Relisys TL766 monitor. OSD menu continually open, wont close. Standby button doesnt always function.
Here is a definite solution to all those having problems with OCS menu on Relisys TL 766 Monitor.
Having tried many of the posted solutions none of which worked. The only option was to visit my local PC repair shop who disconnected the OCD monitor for UK £15.00. Spare parts for this model are no longer available. Only down side was the power indicator light in middle of now redundant control buttons does not work. Otherwise a monitor works perfectly. NO MORE STRESS.
Oct 15, 2008 | Relisys TL 766 Monitor
Screen settings problem
OSD = On Screen Display. Once loaded it is normal for the OSD to stay on your screen untill it times out or you Exit it.
Nov 24, 2007 | Samtron MONO TTL 13 Monitor
Computers & Internet Logo
700 people viewed this question
David Payne
David Payne
