Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Water collecting at the bottom of the refigerator
Could you please help with this problem,,,,,,,it collects inside bottom.
Al Rubin
jr15@cfl.rr.com
  • 943 Answers
Hi thanks for the question the drain tube from the freezer to the drain pan underneath by the compressor is clogged . clean this will solve your problem thanks the appliance doc
Posted on Sep 27, 2008
N325T water collecting at bottom and back internal wall freezing up
That sounds quite normal as the rear panel is the evaporator skin. Check the drain hole at the bottom isn't blocked
Apr 22, 2012 | Refrigerators
My Whirlpool refigerator, Model ER2CHMXPL02, leaks. Water leaks into the refrigeration compartment, apparently from the freezer compartment above. It does have an ice maker. The water leaks down the...
You have a defrost drain that is plugged.You will need to locate the drain and clean it out.Take off the cover for the light and you may see the drain. If not there then pull the refrigerator out from the wall and you should be able to get to it from there.Hope this helped.
Jun 03, 2011 | Refrigerators
Unit runs all the time and water collects at interior bottom floor.
Is the unit cooling properly? Its a broken or misaligned water hose that runs from freezer to water reservoir for evaporation from compressor heat. Or there is too much humidity causing lots of water to collect inside and your unit is running all time, it can be a case of door not closing properly.
- Please check the door if its closing properly without any gap.
- Any broken pipe inside
- Chiller tray flooded or not in its position.
May 11, 2011 | Refrigerators
My GE Profile PS123SGPA BS side by side keeps dripping water from the water dipenser
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!! bstrickmaker@neo.rr.com
Feb 15, 2010 | Frigidaire FRS26H5AS Side by Side...
Leaks water from freezer into refigerator and then out the bottom of unit
remove cover in freezer. unclog small hole where water collects
Feb 11, 2010 | Kenmore Refrigerators
Water collects in the bottom of my LG LRTP1231W
Some units don't have a drain tube. The water flows down the back of the fridge into the bottom and it just makes a mess. It has been a problem ever since they started going "Energy efficient". The drain was a hole and they had to close the holes. If you're lucky enough to have the drain, it will be located inside the back wall of your freezer. The inside walls must be removed. The drain will be in the drip pan, below the freezing coils (fins) in the back of the freezer.
Sep 05, 2009 | LG LRTP1231W Top Freezer Refrigerator
Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Apr 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaks under veg bins.. Cannot tell where it is coming from. Accumulates slowly
This refrigerator look like mine (Picture).
Mine did the same thing. If it is the same then this is what I did.
Look under the there is a collection tray.
This tray collect the water.
At the bottom of the refrigerator (Inside where the water collect) is a cap.
The cap has cap would have holes or a slot that allow the little water to fall to the collection tray.
Mine has slots and was block up.
clean it out and that should do it.
The water should be able to fall to the tray at the bottom.
I do hope this help you.
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water on base of the refigerator
find the drain hole and unblock it faily easy on a fridge on the side by side more difficult need to unplug defrost it remuve the bottom panel inside in the freezeer side of the appliance to access the drain tray do nort attemt to remuve the panel while iced up dfrost is must or coud cause serious damage
Nov 13, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
100 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
