I am trying to re-install my pixma 600R but each time i get to 44% 13 min it stops. I have disconnected firewalls and follwed suggestion in manual. Can you please help. Many thanks. kev
    Sergeant:
    Champion:
  • 214 Answers
Download the driver & software from canon.com and res-install freshly
Posted on Sep 16, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
1-delete all printers in Printers and faxes
Clean player and CD
re-install driver, sometimes you have to run it a couple of times (I know I did for my HP, I even left over night with no results).
after the 3rd time it went through
  • 19,396 Answers
Are you using the printer disk or you downloaded the file from Canon website?
Posted on Sep 11, 2008
  • Ginko
    Ginko Sep 11, 2008
    First ensure the Window user that you are using has Administrator privileges, if it is a limited user (no right to install software) that can be the reason.
    If you are installing from a cd , check that the CD is not dirty or scratched.
    If it is dirty you can wash it under the tap, and dry well with a soft cloth. If it is scratched or faulty you will need to download the software from Canon website.
    Here is Canon download for your printer.
    Put your windows version in Select OS box to activate the download.
    Chose to download the file in my documents when asked.
    After downloading,findthe
    file, double click on the file, if you get troubles ,
    then follow instructions below to reset and reinstall:
    • Unplug printer USB.
    • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
    • Download driver from website and run the file.
    • Follow driver installation wizard.
    • Plug back printer when prompted from installation wizard.
    Regards
  • 13,433 Answers
Hey,
You may have a faulty install media, I will get you a download to the setup program in one minute and you can try installing with it.
How do I install the onscreen manual for my canon printer which is an MG2450 PIXMA?
Hi
I've included a link (see below) which should enable you to install your printer.
Hope this helps.
-Steve
Canon PIXMA MG2450
Apr 03, 2015 | Canon Office Equipment & Supplies
I put a security code .. im truying to unlock my nokia E5 i get : code error .. what can i do ? i need to reset my security code please .. thank you a lot
Hi iba bob...
You can unlock by 2 methods 1)you can get master code from
http://www.unlock-zone.com/
or
http://www.nokialockcode.com/mastercode.php
and
superunlockcodes.com/unlocking-services/rs12wp6/ (You have to pay for these)
2)You can flash(format) your handset to reset code 12345
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Try the follwing.... *check whether your phone or memory card memory full or not If memory is full clear some memory *Scan with a updated version of updated antivirus If problem persists you need to flash your handset
To flash you need
*A Computer
*PC suite of your handset
To flash
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option)
**Don't disconnect while updation process
Than you have a nice day...
Jan 31, 2011 | Nokia E5 Cell Phone
Have a 99 nissan altima that wont heat at an iddle. have changed the 2 thermostats and water pump. also bleed the system pre the tech service bulitin, and still have no heat at times at an iddle. any...
yes,have suggestion.leaking coolant into the passeger side floorboard? film on the windsheild at anytime? suggest a bad heater core. or this,heater core stopped up.needs to be flushed.flush radiator with a common flush found at autozone,advance autoparts stores.or any other auto parts stores. remove your heater core hoses on the firewall[2 small hoses that go from the motor through the firewall to the heater core itself] flush the heater core there manually.push your water hose to the passenger side there and turn hose 'on' and watch the flow out the other side.[both hoses on the firewall will have to be off[or disconnected]to do this properly. your problems here,and since you've replaced the thermostats twice,suggest that this is your issue. thank you for choosing fixya.com
Jan 28, 2011 | 2005 Nissan Altima
Music player does not open
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
Jan 27, 2011 | Nokia 3110 Cellular Phone
Can't shut factory installed alarm off. It disables the engine. Put new battery in keyfab but still won't work. Tried disconnecting battery & waiting, still won't work. Pumped gas 3 times with...
is the security light on? Try ,crank it ,leave the ign. on for 1 min. Crank again,leave ign. on for 1 min.
should reset ,may have to do that several times.
Oct 25, 2010 | 2001 Chevrolet S-10
AC stopped working
Try disconnecting the battery for a minute or so and reconnect it. Believe it or not this has worked for me numerous times. If this doesn't work then disconnect the switch on the accumulator. The accumulator is located in the low side (big) hose near the firewall on the passenger side of truck. Using a paperclip jump the two wires (harness side) together with engine running and a/c on. If compressor kicks on when jumped either it's low on freon or the switch is bad. Hope this is helpful.
May 21, 2009 | 1991 Chevrolet C1500
Clogged fuel - system?
change your spark plugs check spark plug gap
Mar 22, 2009 | 2003 Yamaha YZF 600 R thunder cat
PIxma
Thank you. I did get your reply and tried but with no success ( stopped as before). I wondered whether it is the same Driver for the 600R which is a wireless printer? Thanks, Kev
Sep 11, 2008 | Radio Communications
k24674
jasbo
jasbo
