Question about Dell Inspiron 1501 Notebook
Can i still use the batteries?
Ahm what if the battery still working...but there's a warning every time I open the laptop...how much is the battery oh know can i afford it! why is dat i can still charge the battery as shown on the icon...and i ca still use my laptop...:-)thanks
  • 2,794 Answers
Yes you can still use your laptop.  You can check on e-bay by looking it up by the battery number.
Posted on Sep 11, 2008
Low battery warning
Open the Control Panel and select Performance and Maintenance then Double click on the Power Options . Click on the Alarms tab and make sure the boxes are checked to activate alarms in both the "Low battery alarm" and "Critical battery alarm".
Mar 26, 2014 | Acer Aspire One D270-1679 Atom N2600 1
Battery warning
Just ran into this problem. New 3rd party battery with the badly translated message:
"Battery Life Time in current state is not longer.
Because you may lose your data during using, please replace to new battery.
(honest goods)
Tip> Battery Pack is Cunsumerable device.
This pack is not working correctly or life time is not longer,
please use to replace to new battery (honest goods)."
What I did was when the message pops up, hot ctrl-ald-del > start task manager > right click on it in applications and click "Go to Process" > right click on the .exe file and "open file location" > and just changed the name of the executable file by just putting a 1 on the end of the name. No more pop-ups
Who the hell uses Easy Display Manager anyway? Stupid program.
Jul 19, 2012 | Computers & Internet
Hi Could you be kind enough to advise on the following? I have a dell precision m65 laptop with a replacement none gen battery fitted. The battery icon on the sys tray shows that it is "On A/C...
Unfortunately it may be the battery. This is because the none gen battery will not have the same reading levels as an official one so the Laptop gets confused and decides to say it is 'On A/C Power'.
May 04, 2011 | Dell Precision M65 Notebook
Dear people, I have a acer aspire 8930g laptop. through the battery it works fine. Through the electric cable he strikes out every time. I opened the laptop and cleaned the fan. Fan is working but...
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Feb 19, 2011 | Computers & Internet
Battery Not Identified.
hello
I suggest you a few steps to solve your problem.
  • remove the charger and press the power button till all residue power is radiated.
  • then connect the charger and charge the battery fully and try booting the system.
  • if this don't work check the output of your charger and see if it is working fine.
  • if it is working fine then remove the battery and connect the charger and try starting the system.
  • if it works then there are two things possible.
  1. battery gone.
  2. IC responsible for charging is gone.
i hope you can figure out the problem through this.
Thank you
Aug 07, 2009 | Dell Inspiron 1525 Laptop
Cannot identify Battery
When I turn on my Dell Inspiron 1501 laptop, I get this:
Warning: the battery cannot be identified.
This system will be unable to charge this battery.
Press Any Key to Continue.
Press <F2> 2 times to enter SETUP.
Press <F12> and Any Key to enter Boot Menu.
what should i do?
Jan 06, 2009 | Dell Inspiron 1501 Notebook
Configuring Locked out and password problems
WARNING this will reqire you to open the computer, I cannot be held responsable for any damnage that may occure. Open the computer up (unplug it first!!) and locate a small battery. (Its in there, every computer has one) remove the battery for 24 hours than place it back in the computer, and the comfiguration will be unlocked. WARNING: Your computers time iwill be changed. Please correct the time in the BIOS menu.
Dec 18, 2008 | Compaq Armada M700 Notebook
Thanks again...
Sometimes, the battery alarm is set to high or off and it will automatically warn you when the battery is at a certain percentage. Most newer laptops will even warn you when the battery is going bad.
The AC cord is both the power cord and it will also charge the battery when plugged in as well.
So, it's safe to run on just battery as it may just be telling you that it doesn't have AC power and that you're running only on the battery. My Satellite laptop is setup to warn you when it's only on battery power as well.
Sep 16, 2008 | Dell Inspiron 1501 Notebook
Is it safe to use the battery?
ya absolutely no problem with that
Sep 12, 2008 | Dell Inspiron 1501 Notebook
Black out screen dell inspiron 6400
Try to turn on the system with the charger plugged in and also how old is the system.if the system less than a year then try to get the battery changed and may be the motherboard.
Sep 07, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 1501 Notebook Logo
27 people viewed this question
Alun Cox
