Question about Nortel MER-9417CW Telephon Corded /2 Line Speakerphones with Caller ID and Call Waiting, Almond (MER... (A0674968)
Display goes blank. Clicking sound on line.
Replaced the Adapter a few years ago which solved the problem but not this time. I notice the new one heats up now and has not solved the problem of the display going blank, and a sort of sporadic clicking sound when I pick up the receiver. I am able to make and receive calls. Could the motherboard be the problem? How can I diagnose this problem, get the parts I need, and from where? Appreciate any help before I just throw it away! Rich
  • Rich Hagy
    Rich Hagy Apr 19, 2006
    Also, I note now that a loud hum occurs when I plug the phone. The hum remains even if I disconnect the phone line and handset.
  • Rich Hagy
    Techman,
    Thanks for your quick answer. I probably was too vague on describing by problem.
    The new adapter I just bought is heating up. The phone hums fairly loud and their is noise on the line.
    I assume something is wrong with the phone not the new adapter. Can You give more advise for me to try to fix it myself?
    thank you very much for your help.
    Hagg
    President:
  • 3,130 Answers
If a new one is heating up that means theres an overload in the phone and will certainly burn out a new adaptor or if your saying the new adaptor you bought a couple of years ago is heating up the the diodes or filter inside the old adaptor is bad and replacing adaptor with a new one will fix it . Good Luck
Posted on Apr 19, 2006
  • Larry  Dillon
    Larry Dillon Apr 20, 2006
    Sure But it may not be able to without a meter as if it(the adaptor) is heating up thyere is a short inside the phone somewhere Most likely its gonna be like a zener diode a filter cap or simply an ic thats drawing too much current. The onlr right way to fix this woould be to see how much current the unit draws and get a schematic and start disconnecting things and measureing the current or try to open unit and smell around for heat or by feeling. Maybe you will get lucky and see or feel whats getting hot and that would be the part thts drawing too much current. Let us know what you find as if you need more help I'll be here!! Good Luck
K5 blazer starter
If you did not drain the fuel all the way or put a stabilizer in the fuel then you have gummed up lines for one thing. The other noises are not really concerning.
Dec 02, 2013 | Cars & Trucks
Samsung Ln-T4671F screen is getting darker. The whole screen is darker, not only the right or the left. Also a red vertical line appeared about a year ago, haven't noticed since- don't know of its...
MOST LIKELY YOU HAVE A DEFECTIVE LCD PANEL. Try lightly squeezing the top of the TV. Start from one corner and work your way slowly to the other side. If squeezing the top of the frame clears up the screen problem, you have a defective LCD panel tab. The only true repair is the replace the screen. This cost for a replacement panel could cost more than a new TV set.
Sep 03, 2012 | Televison & Video
We have hardly used our C2 due to continuous house moves[purchssed new in 2005/6] went to set it up today and the screen just has a series of vertical and horizontal line and then goes blank
I to have a C2 rowing machine with a PM3 moniter which i havent used since August last year, and i decided to use it to help loose the excess Christmas pounds and the moniter sounds like it does exactly the same as your moniter with the vertical and horizontal lines then goes blank. I bought the rower new about 2/3 years ago and it hasn't been used too much.
If you find a solution to the problem please let me know thanks (jm@manx.net)
James
Nov 04, 2009 | RTO Concept2 Model D Rowing Machine with...
Averatec 3700 got power but blank screen (screen is good)
hi,
please chek the booting sound is coming.
2.if the sound is coming then this might be the issue with display only.
3.if booting windows sound is not coming then this is the issue related with either m/b or RAM.
4.if num lock is responding(press and release num lock) then this is the issue with RAM otherwise with motherboard.
in case of clarification please revert.
thenk you.
May 13, 2009 | Averatec Computers & Internet
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Tv goes blank, sound stays on
i had an older hitachi. Same problem. It was the capacitors in the comb filter had dried out. Replaced them and it was like brand new.
Apr 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
The base unit goes blank no display
I had this same problem. It turned out to be a bad power adapter for the base unit. If you have another handset that has its own charger than the power adapters are interchangable. try swapping them and see if this fixes your problem.
Mar 08, 2008 | Panasonic KX-TH111S 2.4 GHz Cordless Phone
Display problem
yes big time need cpu fan to work and new greese big time turn it on hi on bios if u can also buy acooling pad on ebay labtop cooler pad keep it cool these so hot killed power chips in it now bad mobo least get that cooler on ebay ok
Jan 19, 2008 | Computers & Internet
Lands Phones Logo
134 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
