Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
Posted on Sep 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SOUND NOT WORKING ON ALL CHANNELS
THIS TV IS JUST PLUGGED INTO BASIC CABLE FROM THE WALL, NO CABLE BOX, AND THE SOULD ONLY WORKS ON A FEW CHANNELS AND NOT OTHERS.
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on Sep 11, 2008
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1564492
Points
12312
Check to make sure that the set is not set for SAP. This is an alternate audio channel that usually contains another language. Some stations broadcast the audio in both others do not.
Dan
Westinghouse VR-2188 will not find channels when hooked up to comcast basic cable box but will if connected straight into wall, whats wrong? Cable box works on all other TV's in the house also so it is...
Make sure you have selected "cable" as the source input to the tuner. If there is a selection for both digital and analog channels when doing a channel scan then select it.
How do i setup my tv through surround sound without a cable box?
Unfortunately Without the cable box you will have to screw the coax cable into the coax input on the tv or You can screw the coax cable into a vcr and then plug the Audio / Video RCA plugs from VCR out to TV RCA input (You will have to control the channels from the VCR and the volume from the TV remote)
1helpful
2answers
No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
3helpful
2answers
Panasonic 32LX70, I have basic cable and the sound
I have the same issue. Its not the cable because all the other tv's are fine when tuned to those channels....Any luck?
TV will not turn on to channel 4 everytime. I have a cable box and need the tv to remain on channel 4.
As long as the tv is not unplugged it should stay on the same channel when turned back on. If you have the tv plugged into the cable box, when the box is shut off it basically unplugs your tv and the tvs memory is reset. The tv should be plugged in to its own outlet or leave the cable box on and turn off the tv. If you turn everything on, cable box and tv, and have a picture, go into the tv menu and auto program the channels, it should only lock in on channel 4 since it will be the only channel the tv will receive.
Cable from wall does not work through box.
What box? What is the wall jack connected to? There is not enough information in the description to provide an answer.
My sony wega 36' circa 2001 will not receive cable signal.
If none of the r.f. inputs are working and you do not get local channels off of a pair of rabbit ears. You may have a bad tuner. Which you can get replaced for 125.00-150.00 or you could run the cable into a vcr input and use audio/video cables to connect to a video input on the tv and switch tv to that input and run the channels using your vcr. In other words, use your tv as a monitor and use the vcr tuner to pickup basic cable. Hope that takes care of it, Russmann.
10helpful
4answers
Sega mega drive - how do I plug it into tv?
Ok, a few basics to hooking up your console. Firstly you should have two cords a power cord that plugs into the wall and into the back of the console. Another cord should also plug into the back of the console and the other end should be plugged into the back of the television into the slot called in. However if this plug is already taken by a vcr you can hook the cord from the sega up to the vcr in port. After it's all plugged in and the console and tv are on and it's directly hooked up to the tv then change the tv channel to 3 or 4 and you should have something on one of those channels. However if you hooked it up through the vcr then you have to go to the channel that normal has your vcr then change the channel on your vcr to 3 or 4. I think this is all you need to know good luck.
9helpful
7answers
No channels
i had the same damn problem for 3 long hours but i found a solution i have olevia 32 inch tv (720). all you gotta do is go to menu>setup>tv>auto channel search> cable> standrad search
3answers
No sound
have you check with other input like a vcr?...good luck
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
