Question about Panasonic Audio Players & Recorders
I have Panasonic SC-AK750 Mini System and of late it keeps showing F61 on the screen before it switches off. do you know what it is
  • 4,234 Answers
The F61 indicates protect mode. This means that a problem was detected inside and the unit shuts down to prevent further damage. This is usually the output amp pac or the regulator IC. The amp is attached to the heat sink in the rear of hte unit and should be marked RSNxxx.
Dan
Posted on Sep 11, 2008
I require a user manual for a panasonic SA AK 750 stereo system
Hi pjwivell ..
Are you sure that it SA AK 750?
well here is a here for SC AK750
download the manual and try if it works for you..
http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Mini-Systems/model.SC-AK750
please give me update if you had any success... thanks
Jun 27, 2011 | Audio Players & Recorders
F61 will not come on
F61 is an error code that shows amplifier output chip is defective and need to be replaced in Panasonic SC-AK640 unit.
Amplifier output chip replacement requires soldering work and local repair shop will do this job as it is not user level repair.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Feb 10, 2011 | Panasonic SC-AK640 Shelf System
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Panasonic SC-HT995 locked
check the fan, if its dusty clean it then run the player. If it works, your in luck. If the fans are moving and f61 still shows up, the D-amp IC is shortened ( inside you will see IC 5000/IC5200 / IC 5300, these needs to be replaced) its the one by the big cooling fins (behind the rear fan)
Nov 11, 2009 | Panasonic SC-HT995W System
When i power on the screen shows F61
Another user wrote that by redoing the speaker wire connections and turning the volumn on low at start up he solved it. Try this and let me know if it worked. jim@firstservicetechnology.com
Jun 15, 2009 | Panasonic SC-HT67 System
Panasonic SC-AK750 Mini hifi
The problem is usually either the amp-pac or a regulator. If the problem is the amp-pac, expect to pay around $90 or so for the part alone. The regulator is much less. Yes the unit is repairable, but get an estimate on the cost as some of the newer units may be close to that cost as a replacement.
Dan
Sep 24, 2008 | Panasonic SC-AK75 Shelf System
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
System keeps shutting down
Code F61 can point to trouble in the audio output ic chip, are the loudspeakers connected correctly no short circuits.Also check that the cooling fan operates.
Sep 08, 2007 | Panasonic SC-DT310 System
121 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
