CD-Rom cd-dvd Rom reads only music discs plus shows all titles through explorer and my computer driveE: Data discs will not read or show any data on window explorer.Inluding of autorun. PLease, any suggestions
    New Friend:
  • 68 Answers
Shut down PC & disconnect the wide flat data cable connecting the device to the motherboard. Boot the PC and do nothing. Shut down again and reconnect the cable as it was. If possible replace the old cable with a fresh one.
Try & reply.
Posted on Sep 11, 2008
I had to restore my emachine to factory settings
Open "My Computer".
Insert a "data" CD, and hold the LEFT-SHIFT key down for a minute.
Watch the icon for the CD-drive change from the "standard" icon to something specific to the data CD.
Right-mouse-click on the CD's icon, and choose "Explore",
to open Windows Explorer to view the "data" files on the CD-disk.
Dec 11, 2009 | E-Machines emachines (emachinees) CD-ROM...
I am having a problem with my DVD rom. I put a disc in there (DVD or CD) and it shows what the disc is and even names all the songs on it, but then a message comes up saying- ? Windows Media Player cannot...
It just might be a problem with the laser carriage motor that moves the laser assy back and forth to read from the inner portion of the disc to the outer portion. If it can't move from the reference position, it won't read anything more than the initial data on any disc. Hope this helps. Good luck!
Nov 07, 2009 | Hitachi GD-8000 16x 40x IDE DVD-ROM Drive...
Help!
you need to clean the lens with a lens cleaner...
Jul 12, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Dell XPS 200 CD/DVD reading problem?
the reade part of ur CD/DVD drive is damaged while the Burner is still ok .
1/use the cleaner disc.
2/replace the part.
3/replace the drive as a last solution.
plz do rate this post.
Dec 29, 2008 | Dell XPS 200 PC Desktop
Data are not shown
most older drives can't read multi session... you need to have a drive installed to be able to read multi session burn. there is no software tweak that can fix this... you need to replace the drive. otherwise burn the data as single session.
Jun 03, 2008 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
DVD READING PROBLEM
Hi , look in software store having a cd cleaner , to clean the optic laser of the dvd./ something block the reading of the data of the dvd disc.
Jan 16, 2008 | Sony (1-796-293-13) Plug-In Module DVD...
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
LITEON DVD/CD-RW CAN READ DVD BUT NOT AUDIO/DATA CD.
I would suggest cleaning the drive with a cleaning dvd, $19.99 at most retailers. Or you can open up your computer and verify all connections to the drive are good, disconnect and re-connect to be sure. Hope this helps.
Sep 15, 2007 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
