Question about Whirlpool LSR5132PQ Top Load Washer
My wirlpool ultimate care 2
My washer is spining, but not long enough or the water is not draining correctly, because I run it through any cycle and the clothes come out soaking wet. Can you help me with any info to fix this problem? Brittany
  • Anonymous Mar 15, 2014
    Our bathrobes stay soaking wet after any of the cycles are used. We cannot get them to squeeze the excess water out of the garment.
  • 641 Answers
Try the following 3 steps : - Check that filter's machin is clean (in case it is not clean, it will prevent water outlet). - Step before spining start, there is a pump that should drived the water out the drum. You should hear pump's activity. In case you don't hear it, you should check that pump receive power, if there is no power-you have a problem with the timer, if it receive power- you should replace the pump. - Check that no water leak or drip to the drum when the machin dosen't work- In case water coming in, you have a problem with the inlet valve that can no longer completely shut off when the electricity is turned off to it. To fix this- You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! In case valve cleaning dosen't help, you should replace it. Good luck.
Posted on Apr 19, 2006
My washing machine is taking water but not draining and not spining
This problem may be related to a bad lid switch. If the level sensor works, that is it stops filling up when at the correct level then it is looking for the lid switch ( To start working safely!!).
Regards.
Aug 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer wont drain
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Jul 19, 2009 | Tecnik TKL9260 Front Load Washer
The spin cycle for my
Dear shelldon39, Fri 2-20-2009 9:24pm EST (USA)
Some machines will shut down during the spin cycle as a precaution to prevent damage!
They will do this if you overload the washer with clothes and/or use too much detergent!
If this doesn't help please get back to me with more details!
jack
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Won't drain water for rinse
your lid switch is defective..replace onthejob
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Sep 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSR5132PQ Top Load Washer Logo
102 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
