Question about Dishwashers
Simpson Silencio 850 leaks - the water doesn't seem to stop filling. Replaced all seals, but it keeps filling until it leaks and we have to stop it manually.
  • Julie Sarll Nov 21, 2011
    We seem to have the same problem. What was your solution?
Hi, I've just purchased a 2nd hand model of your dishwasher. mine actually leaks from the black lining underneath. I've just patched it with some Sellys bathroom sealant. I don't know more about your problem but sounds like it could be something not timing out to stop the water, maybe buy a new 1 :P
Posted on Sep 18, 2008
My Simpson ezi sett 7.5 always fills to full even when set to low. i have replaced the pressure switch and still fills to full.
Check the rubber hose from the pressure switch down to the bowl for any holes or splits allowing the air pressure to escape. Also check that water valve is stopping the flow. Start to fill then press pause. Water flow should stop immediately. If it keeps flowing or is slow to stop then replace the inlet valve. Try it several times to be sure.
Dec 18, 2016 | Simpson Washing Machines
User manual for simpson silencio 850
try searching on Google for make model ,manual .we have none here
Jul 09, 2015 | Dishwashers
Water keeps running, toilet not shutting off totally, tank will fill then we have to pull up float and hold it a while to stop water, doesn't overflow, just keeps running, doesn't shut off...
Hi snowjobs847...
Try resetting your float level to a lower water level in the tank, the extra pressure put on the seal may make it reseal.
If the above did not work:
You need to replace your "ballcock"...the ballcock (inlet valve) is non-repairable, has to be replaced with a new one if you cannot get it to stop leaking.
Please take time to rate me
Sep 04, 2011 | Home
Hi i have a simpson esprit and I can't stop the
If the water continuously keeps filling the tub of the washer this would be due to either you have a bad pressure switch or the hose that is connected to the pressure switch that goes down the side of the unit and connects to the tub has either comes off its connection point or has sediment or debris inside the hose itself which would cause the same issue here is also a basic video of how the pressure switch test is done click this link http://www.youtube.com/watch?v=HZZ2bDMspj8 if you have any further questions message me back and please remember to rank this opinion when our chat has fully concluded it allows me to continue helping others in similar situations in the future. Thanks again for using Fixya
Rick
Jun 12, 2011 | Washing Machines
How to replace the door seal on a Simpson Silencio 850 Dishwasher Model No. 82B850WH. The part No. that I have for the door seal is 0208400158G & is Electrolux part number
The around the tank seal just pushes into the groove. make sure that you copy the way the old one comes out. The bottom of the door seal is a bit awkward. Thsi has some screws that are difficult to access. Take the door liner off and possibly two of the hinge screws so that the door can swing up at the bottom to allow easy access to the screws. You might get someone to help ny holding the door while you do this. Check tah the new seal fits the same way as the old one comes out. Then reassemble
Aug 01, 2010 | Dishwashers
Simpson silencio dishwasher over filling . have c...
Clean the filters and filter bowl and if that doesn't solve the problem check the pipes to the pressure switches on the bottom right side (as you face it ) are not blocked and check that the pressure switches are working by blowing in their tubes and checking for a "click" sound and test with a multimeter for an open and closing circuit.
May 20, 2010 | Dishwashers
Leaking dishwasher simpon silencio 850. not alot of water 100mls or so. can't see where it is leaking from, there are some water marks on the front right underside.
Commonly leak from door seal- check seal for rips, notches. Also common to leak from the black retainer that the door seal sits it-remove the seal (they just pull off) and shine a torch from inside the dishwasher around the back of the seal retainer, and see if there are any gaps around the outside of the seal retainer. Repair with silicone sealant if any gaps. Other things to check- check the screws that hold the top basket runner on are tight- there are two holes in the runners, move runner until you can see screw, check they are tight. Also check water level is not too high inside machine whenits running- there are three vertical lines on the bottom spray arm support tube- water level should not be above top line. If still leaking, call in the experts!! Good luck!!
Mar 13, 2010 | Dishwashers
Water not emptying in dishwasher model simpson silencio 850
How long does it take to wash dishes completely in a ASimpson dishwasher
Apr 18, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
Simpson silencio 850 dishwasher. not sure where to put upper wheels for top basket
Halfway and at the end. Put them upside down on the right-hand side to avoid the tray jumping when sliding.
Nov 07, 2008 | Dishwashers
Dishwasher simpson (silencio 850) model 52B850SF * 04
Check that the pressure switch tubes are not blocked on the underside of the machine on the right hand side and that the pressure switches are working when you blow down their tubes. You will hear them click on and off.
Nov 05, 2008 | Dishwashers
Dishwashers Logo
847 people viewed this question
Top Dishwashers Experts
