Question about HP Office Equipment & Supplies
Hp printer say cartridge failure but have replace with new cartridge.
  • 167 Answers
You need in printer setup install manually cartridge. I assume that is inkjet printer. It's stupid but must do that.
good luck!
Posted on Sep 11, 2008
Hp officejet j6480 cartridge error problems
This type of fatal cartridge error (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. However, our test group has also seen these failures with brand new cartridges. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below on how to access respective printer's service menu and correct:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings:http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges):http://www.youtube.com/watch?v=8fE-IM4AVMc
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
Jan 12, 2012 | HP Officejet 5610 All-In-One InkJet...
I am getting a error message saying the printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume printing. I replaced the cartridges and it does not...
These printers have been known to have ink system failure errors. This message can also be caused by using compatible or re-manufactured cartridges. We believe the HP Live update software is also responsible for "dobbing" on you if you use any other brand.
A Fix for the ink system failure can be found below Not sure if it will help with your particular error but it wont hurt to try.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
Good luck
Apr 14, 2011 | HP Photosmart C6180 All-In-One InkJet...
0xc18a0401 ink system failure error on hp C6180 printer
Check out this link.
http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp/
Apr 28, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP 1050c....Hi, i am getting error on display for
Are you using HP factory new cartridges or some third party cartridges or even wores a refilled cartridge?
80% of the time, that's the cause of the failure.
Don
Feb 24, 2010 | HP DesignJet 1050c plus InkJet Printer
Ink Cartridge apears to be missing or damaged
Just to begin with, please tell me you are using a factory new HP cartridge and not some knock-off cartridge or even worse, a re-filled cartridge.
Either the third party cartridge or a re-filled cartridge are the most, by far, reason for the printer reporting a cartridge failure.
If you are using a factory new cartridge, then you need to contact the store that sold you the cartridge and ask for a warranty replacement on the new cartridge becuse it was an "out-of-box" failure.
Don
Feb 24, 2010 | HP Photosmart C6280 Printer
My HP J6480 printer will not recognize the ink level on a new Officemax ink cartridge. printer keeps indicating that the ink cartridge needs replacing.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 17, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
Ink system failure (just put in new cartridges)
you should contact the hp support for this. if the printer is in warranty you might get a replacement as well because it is an issue with the printer itself.
contact HP technical support as soon as you can .
1-800-474-6836
Nov 22, 2009 | HP Photosmart C6380 All-In-One InkJet...
HP J8750 Cartridge error
I had this "Cartridge error" problem on my HP J5780 printer. Replaced the cartridge, but still got the same error. Then removed the cartridge and used a cotton swab with a little denatured alcohol, and gently and carefully cleaned the contacts in the printer. Followed this with a dry swab to be sure no alcohol left. Replaced the original cartridge, and have been using it for a week now with no more error message.
Casey K.
Nov 07, 2008 | HP Officejet J5780 All-In-One InkJet...
Pen failure message from utility
HP tech support suggests cleaning the ink cartridge contacts and the contacts inside the printer for the cartridges. If this does not clear the problem, try replacing both cartridges (color and b/w) with new ones.
Jul 25, 2007 | HP PSC 1210 All-In-One InkJet Printer
35 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
