Jensen VM9410 Car DVD Player Logo
Brian Holliday Posted on Apr 18, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Radio My radio station is not coming in.
  • Brian  Holliday
    Brian Holliday May 01, 2006
    The connection to my radio are all the way in. My radio station still comes in and out.
Anonymous
Level 2:
Champion:
  • Expert 277 Answers
  • Posted on Apr 20, 2006
Anonymous
Expert
Level 2:
Champion:
Answers
277
Questions
Helped
171576
Points
362
Hi first, please make sure next time to be more specific, so we could understand what are you talking about and is the problem from what i understand: your ANTENA isnt hooked correct check the ANT its socket the line to the player and make sure its connected well inside the player's back socket good luck
1helpful
Radio frequently just stops broadcasting and eventually comes back on
Peggy, Is the radio actually switching off or do you just loose the radio station. If radio is shutting off, there must be a bad wire/ plug connection, loose plug, or maybe bad ground.
If loosing station, have Arial/antenna connections checked, maybe upgrade to better antenna. Some stations just do not send out a strong signal which can also cause loss of station.
When I try to find radio station all I get is static. How do I use radio function
You need to have an antenna to have your radio stations come in clear. If you just hear static, your antenna sounds like it's not there!
Why does my radio alarm only work with one station?
When you're setting the alarm you should be able to choose any of the stations programmed into your radio. Just press radio to choose radio for the wakeup, and press one of the presets. You can also set the volume at which it comes on.
Radio wont set stations
hi, does the radio go back the standard settings when you turn off the key, if it does than try checking the fuse for the constant power supply as this controls the time memery and the settings for the stations, if not try holding the station button down for 3 to 4 sec
hope this helped
How come i cant find the radio for my Phillips go gear vibe?
From the main menu, select the icon that looks like a little radio
To search for the next stronger signal, press and hold the up or down arrow
To fine tune the frequency, briefly press the up or down arrow
From the main menu, select to enter
radio mode.
• The earphones cable acts as FM
antenna.
Manually tune a radio station
While in mode, you can manually tune to a
radio station:
1 To search for the next stronger signal,
press and hold / .
2 To fine tune the frequency, briefly press
Auto-tune preset radio
station
The auto-tune feature of GoGear Vibe helps
you find radio stations and save them under the
preset numbers.
1 While in mode, select [Auto tune] >
[Yes].
»» The radio automatically tunes radio
stations and saves the frequencies to
presets.
»» There are 20 presets available.
»» To stop auto tuning, press .
»» To exit radio, press and hold for 2
seconds.
EN
Just bought a car and it had hardwired sirius radio already installed. I called and activated it with Sirius radio and tried to get assistance from them on how to get it to work. They gave me instruction...
The "hard wired" version that you speak of apparently only refers to the power supply.Do you have a seperate display for the Sirius unit? Now, you failed to mention the type of radio (factory or aftermarket); so, if you have to use an "empty radio station" then you have an FM modulator. This modulator could wired or wireless. The wired version interrupts the vehicle antenna wire and the station on said modulator is usually preset to either 88.1, 88.3,88.7, or 89.1. There is no need to power this modulator up, it comes on when then Sirius comes on. One way to check for power is to turn on the Sirius unit and tune your radio to an occupied Fm station. Wait a few seconds and listen to the reception. Turn off the Sirius unit, the reception should improve for the occupied station. If it is a wireless FM modulator it also has preset stations that you can change but, extending the wieless antenna will greatly improve your reception of the Sirius stations.
What radio station do I tune the radio to for the satellite radio to come in
Look on page 12 of the Roady 2 user guide. There are 12 stations listed. Pick one that is not in use in your area
Radio stations
Set the station you want to wake up to in the "AL" preset memory. You can download the manual from the link below: http://157.254.235.130/public/rp3722.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Top Jensen Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
