Question about Olympus D-400 Zoom Digital Camera
Olympus D-400 Battery Cover
Battery cover came off. Does not appear broken. However, unable to put it back on slide. Looks like the case has to somehow be loosened.
  • Michael Baum Apr 20, 2006
    The tabs were not broken. However, I was able to remove the small screws, one to the right and the other on the left edge. This allowed me to gently pry the case enough that I was able to put the tabs on the end of the cover back into the slides.
  • chuckgcs Jul 13, 2008
    Just noticed that the battery cover on my D-400 has a broken tab at the end, and on the same edge the tab on the camera front cover that mates with the center tab of the battery cover is broken. This translates to mean that the front edge of the battery cover is only being held to the body by the hinge stub. It's going to require both a battery cover and body front cover to properly repair it. As I begin my quest, I would appreciate any suggestions. BTW, we love this camera.
    Chuck
    President:
  • 3,130 Answers
Theres a lttle tab thatmay have broken off I,ve seen it a zillion times.. Consult your owners manual and it will show you how it goes on and if it dosent work like the manual says it probably broken good luck
Posted on Apr 19, 2006
SOURCE:
How do i replace the battery in the garmin streetpilot c330
Follow these steps : 1. Determine that you do have a Garmin GPS with a replaceable battery. Find the information by checking the manual or with a close inspection of the back and sides of the GPS unit. GPS units that have a battery that can be replaced by the owner will have a battery cover lock on the back or side; it looks like a small sliding piece of plastic with slots or ridges.
2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
May 16, 2011 | GPS
How do i remove the battery out of my garmin 1300
  • 2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
  • 3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
  • 4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
  • 5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
  • Mar 01, 2011 | Garmin nuvi 1300 Car GPS Receiver
    I have a Sentry OA5835. I am unable to open with factory combo and key. help
    Sounds like the batteries are dead.
    How to install sentry safe batteries
    slide open the battery cover located just below the keypad.
    Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
    reconnect the connector and put back the battery holder. Slide the cover back in place.
    How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
    turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
    Mar 11, 2010 | Sentry Fireproof Safe
    Unable to open electronic safe
    Locksmiths say this is how to install sentry safe batteries
    Mar 06, 2010 | Sentry Fireproof Safe
    Change battery of sentry safe
    To install sentry fireproof safe battery
    reconnect the connector and put back the sentry safe battery holder. Slide the cover back in place.
    Dec 01, 2009 | Sentry Fireproof Safe
    Broken track
    I have the same problem. I contacted Olympus and it is 29.95 plus tax to repair. Right now I am getting around the problem by holding the cover and controlling it as I open or close to make sure the camera turns off and on.
    I purchased a second reconditioned camera from Olympus on the auction site for $35.00 and it arrived yesterday.
    It comes with everything except a remote. The battery is the newer L12B. Considering the cost of a replacement OEM battery and the camera looks new, it seemed to be the best work around to having the camera repaired.
    I keep it because I have the underwater case for this model and to buy a case for another camera is big bucks..
    Jun 28, 2008 | Olympus Camedia C-50 Zoom Digital Camera
    Error message: battery cover open. This message appears in the window and will not let me operate camera until problem is resolved. The cover is closed, but the message will not go away. I have re-set...
    Hi X,
    There's a little piece of plastic on the battery cover, that presses a switch when you slide the cover closed. Check that manually with a tooth pick and the the battery in place. Don't smash it. I have a Olympus FE -280 and it only happens when I put the cheap Chinese battery in.
    If you are in the least uncertain, call Customer Service.
    Best regards, Paul
    Jun 12, 2008 | Cameras
    Got a problem with the lense
    I had the same problem with mine after it had been dropped on the ground.  I undid the two screws at the bottom which holds the sliding lens cover on and took the cover off.  Check the small black lever inside.  It might be broken.  I replaced the part from an older model and but the cover back on.  I works fine now.  I hope this helps
    Feb 04, 2008 | Olympus MJU 400 Digital Camera
    Cover open, unable to take a picture?
    The cover opens in two positions. To completely open the lens cover for shooting images, slide the lens cover over until you hear two clicks. When the camera is on the first position, you can playback images.
    Sep 01, 2005 | Olympus Camedia C-40 Zoom Digital Camera
    Cover open
    Aug 31, 2005 | Olympus Camedia D-40 Zoom Digital Camera
    Olympus D-400 Zoom Digital Camera Logo
    61 people viewed this question
    Top Olympus Cameras Experts
    Steven Wander
    Steven Wander
    Jerry Greenberg
    Jerry Greenberg
    Steve Allison
    Steve Allison
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
