Question about Cameras
I slipped over at the edge of the pool and my digital camera fell in the pool. Can it be repaired?
    Genius:
  • 1,689 Answers
It will depend on the degree of the damage, it will always be best to remove the batteries and then get a hair dryer (Blower) and blow dry the camera pointing the air to the battery compartment. the most possible part that can be damaged here is the camacitor and the LCD since they are not wet tolerant like the other parts in the camera. you may either try to open the camera up to make it dry faster or take it to a camera repair shop for further repair and parts replacement.
hope this helps
Posted on Sep 11, 2008
My camera fell in the pool
Put it in a bag with dry uncooked rice and contact a repair centre that is specialised in repairs of electronics that fell in the water.
Feb 06, 2014 | Canon EOS 550D Rebel T2i Digital Camera
My camera fell in a pool
Unless you immediately pulled out the batteries (main battery and back up battery) then the chances are that the water shorted out the circuit and it is probably beyond economic repair
Dropped my Leica
Try the steps given below:
1 Remove the memory card, then install the new batteries, when you turn it on it should work.
2 The next thing to try is examining both the battery and flash card door. There's usually a little switch on both doors that activates when the doors are closed. It will be a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be a jury rigged with a small glued-on replacement.
If you still face the problem then there is some internal problem in camera, you need to take to service center to get it repaired.
Hope this helps.
Shane
Jun 16, 2013 | Leica C-Lux 1 Digital Camera
I turn on the camera and the screen starts flashing. lenses wont come out all the way. Fell in the pool.
if it fell in the pool you wouldn't have turned it on instead you would have pulled out the batteries and place the camera in a conducive environment for it to dry for about 2hrs before turning it on......Anyway you can still try..
Jul 12, 2010 | Cameras
Leak in pool
oooo.... thats tricky.... grab a vinly repair kit at the pool store... cut the patch in a rounded form .... (circle is best)
you only have a couple seconds to do this once glue is applied to the patch.....-> fold the patch over itself with the glue tucked into the fold, head under water and right above said leak... unfold and rapidly apply the patch....smear out any air you see in the patch towards the edges...
finally take a test syringe (available at the pool store) with some test dye and shoot VERY SLOWLY the dye at the edges of the patch... if you fixed it the dye will just kind of hang out.... if you still have a leak the dye will "slip" out of the pool... and youllneed to pull off the patch and start again.... good news is its the coolest job on the honey do list
May 23, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Camera fell into pool; was retrieved in 3 sec.doesn't work
You said, "Camera fell into pool; was retrieved in 3..." But you failed to specify if 3 is seconds or minutes or hours. If 3 is seconds, i.e. you retrieved the camera in 3 seconds, then you should be in luck. The first thing you should have done is pull out the battery/batteries. This is to ensure that there will be no leakages of electric current across the electronic components. This is what actually will destroy the camera. Once the batteries are out, the camera needs to be dried. But to be sure that the camera dries well it needs to be opened up. This is the only way you can be sure that there isn’t still some water lurking in a tiny space/corner somewhere inside the camera. What this means is you need to take it a proper technician. Your dealer should be able to provide one. However if 3 is in minutes then you may not be in much luck but you should still take it for repair for a proper assessment.
Sep 03, 2009 | Canon PowerShot SD1100 IS Digital Camera
Fell on the pool but it's off when it fell and it turned on but later on it did'nt turn on anymore
The water inside the camera became conductive and did damage to components on the circuit boards, and possibly did some damage to some of the mechancial parts. The camera would have to be rebuilt.
From past experience this type of repair has not been worth the cost. I would shop around for a new camera.
Jerry G.
Apr 26, 2009 | Kodak Easyshare 1725043 M893Is Digital...
Ixus 75
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 07, 2008 | Canon IXUS V2 Digital Camera
My digi cam fell down ???
This is going to be new camera I am afraid. The repair options are limited because of lack of parts availability Look on your local internet for repair firms in your part of the world
Jun 11, 2007 | BenQ DC3410 Digital Camera
Cameras Logo
79 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
