Rotel 600A Receiver has worked beautifully, albeit probably ony a couple of times max per week, for 30 years. Suddenly 'Bang' and the AC fuse has blown ! Replaced fuse (you never know !) and it simply faled immediately. Any ideas anybody. No, it certainly doesn't owe me anything, but it fitted in very nicely where it was !
  • 4,234 Answers
I wuold estimate that the rectifier section of the power supply has failed. I don't recall whether that unit uses a bridge rectifier or separate rectifier diodes. In any case, you are looking at $15 worth of parts or so. Add in your local labor rate for the total repair cost. This should be a simple repair for any shop that repairs audio gear.
Dan
Posted on Sep 11, 2008
Electric storm, audio went out. Any way to check? or it the unit "shot"?
If the Unit Powers On then most probably the Fuses could have gone bad You will be able to replace the Main Fuse yourself but REPLACE WITH THE SAME KIND OF FUSE in terms of RATING
Jun 24, 2015 | Rotel RX-950AX Receiver
Fuse for rotel amp for RB-870BX
IF THE FUSE YOU ARE PLACING IS THE SAME TYPE AS THE ORIGINAL YOUR AMP HAS A PROBLEM WHAT YOU MUST DO IS TO SLIGHTY INCREASE FUSE BY 100 MAMPS PER TIME IF IT IS IN THE TRANSFORMER CIRCUIT YOU CAN INCRESE IT BY 2 AMP MAX IF IT IS IN THE MOSFETS CIRCUIT YOU CAN INCRESE IT BY A MAXIMUM OF 500MAMP LET ME KNOW THE RESULTS
Mar 04, 2012 | Rotel Audio Players & Recorders
Starter suddenly stopped working. Loud bang when
It's most likely a timing problem, you may try too adjust it yourself; Loosen set screw on distributor and get a timing light. there also a chance it jumped a timing gear when you heard the loud bang..
Jul 11, 2010 | 1994 Chevrolet Corvette
Ice maker only produces 30 cubes per day (24 hrs) since new.
You probably need more water pressure going to the frig. check that first.!!
Mar 22, 2010 | LG LRSC26980 Refrigerator
Suddenly, for the first time in all the years I've had this Sony receiver, a messege pops up on the front of the receiver saying "protector". What is this??? I have NO idea and don't know what to do. ...
Internal problem probably needs output transistors and a dual emmiter resistor (could a couple other parts too). Parts and labor should be about $100 to $125.
Jan 10, 2010 | Sony STR-DE605 Receiver
Same Problem - Suddenly Died ~2yrs old, very light use.
Probably a fuse inside the unit. Can be caused by overheating or by door switches not working properly.
Sep 10, 2009 | Panasonic NN-P794SF Microwave Oven
Rotel Receiver RX-950 AX popped and then quit
there would be life in the old girl it just depends how much you love her and how much you are willing to spend to get her fixed ?? some old rotels are still fetching good money so it might be worthwhile getting a quote
May 26, 2009 | Rotel RX-950AX Receiver
Loud bang, sounds like the motors going to drop out when the compresser kicks on,17 years old, relpace/repair
The actual internal motor in the compressor dome is mounted on springs. Over time these get weak and hence the loud bang noise when the motor hits the sidewall of the compressor housing. It is not too serious and will probably work for ages. Just anoying. Leave it until it really packs up.
May 04, 2009 | Heating & Cooling
64 people viewed this question
 Grubhead
Grubhead
