Question about Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera
Black screen i own a canon digital IXUS 800 IS and when i turn it on to auto or manual the screen is black with the icons white as normal and photos turn out black-tried pressing disp. button which worked for a while but now it just turns the icons off - tried resetting to factory settings and no change i help - please - dennis mannina - london
  • 2 more comments
  • raul alkaim Sep 11, 2008
    I have the same problem with a Cannon Powershot si IS. I would like a help to solve the problem.
    Thank you so much.
    Raul Alkain
  • kayecee1111 Nov 29, 2008
    i have the same problem..the lcd turns black..how can i fix it?or where should i go to fix my cam?tnahk you
    i am afraid of opening my camera?what else should i do..?i tried some of the troubleshooting but nothing happen to my camera.what other option could help me about it?thank you.
  • Ellarie Dec 14, 2008
    I, too, have a problem with the LCD screen.  It is black in Manual, Auto, and Scene modes.  If you tak a photo it WILL show up on the LCD under photo recall.  The movie mode shows up, as well, so I know the LCD is not broken.  I tried the advice listed below.  It does not work.
  • 2,071 Answers
If your camera is still under warranty, the best thing you can dois to take it to the nearest official repair shop and Canon Digital Cameras shouldfix it for free.
If your camera is out of warranty, or if Canon refuses to repairit for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some ofthe methods listed here to repair it yourself. These simple methodshave helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon Digital Cameras has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and drycompressed air (20 lbs) set the tip between the lens turret and thecamera body and turn on the air while moving the tip around the lens.It should remove all dust and sand. Turn the camera on and it shouldfunction fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but veryoften in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon Digital Cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!)It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras.They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
Hope this may help you;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 13, 2008
How do i set my ixus 750 to take black and white photos?
Set the Photo Effect to "B/W". For full details see the "Changing the Photo Effect" section of the advanced guide (page 57 in my copy). If you need the manuals, you may download them from here.
Jul 08, 2011 | Canon PowerShot SD550 / IXUS 750 Digital...
Screen went black
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Feb 27, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Hi, I have a Canon IXUS 95IS camera.. For some reason, when I attempt to take a photo, the LCD screen isn't displaying what is actually in view? In movie mode it comes up on the screen but when i flick it...
Ah yes! you have pressed the display button. Turn the camera on and you see the icons in the display, look for the Disp button and press it, the display will cycle through its modes icons, black, image and icons.
Jan 22, 2010 | Cameras
I have a Canon Digital IXUS 9015, i was wondering where the setting is for black and white photos?
On the IXUS 900 you can not use black and white, although you can change it to black & white when you go to print it in the shops or on the computer in programs like adobe, zoombrowser or windows.
Oct 01, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
White/black "noise in view finder - will not take photo
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Mar 29, 2009 | Canon PowerShot S200 / IXUS 178 Digital...
Taking black and white photos
Follow the instructions in the "Changing the Photo Effect" section of the manual (page 101 in my copy). If you need a manual you may download a copy from here.
Mar 25, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Taking Black and White pictures on a Canon A430
Place the camera in manual mode (M on the dial). Pess the 'Function' button and icons will appear at the right of the screen. Select the second to the last icon, this is the "My Colors" menu. Press the right keypad button until you have selected "BW" for black and white.
Nov 21, 2008 | Canon Rebel XT / EOS 350D Digital Camera
IXUS 500 Screen Not Displaying Picture
Did you see the posting regarding the image sensor? I am exibiting the problems which sounds like it could be what you are seeing. I went ahead and send an email to canon. we will see what happens. I suggest you do the same.
-MitchDZJ
Oct 25, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Canon Ixus 86015
Sounds like you (inadvertently?) had the Color Accent Mode turned on (an icon which shows an eyedropper with an A next to it), which is available on the same menu where you select Manual Mode.
When you press the Func/Set button, with the icon in the top left corner highlighted, along the bottom you will see the options available, including the Color Accent Mode, any of which are selectable by using the left/right arrows and pressing the Func/Set button again.
May 27, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Black Screen/Viewfinder
Mine too! Thank you so much for posting this issue!!
Apr 22, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera Logo
201 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
