Question about Tomtom ONE GPS Receiver
Solution for fried TOMTOM
My TT has fried on my car lighter. Reseting the TT don't work.
I changed the inside battery, but same problem. When I switch on it stays black and the green led is on, and also it become hot...
Is it possible to find on the web the "How to Repair it alone" ?
Thanks to all FixYa's experts
    Novelist:
  • 158 Answers
Please search for other posts regarding this from posted by "homemender" . You will have blown U24 and U25 IC's inside. Its not possible to replace these by normal soldering methods as the components are micro small .
Posted on Sep 13, 2008
My tomtom has a red X and a disk in the corner. It will not let me exit out. I have tried reseting but nothing. What could I do
1. open your tomtom as a folder 2. copy all info from tt to a new folder on your computer 3. format tt in fat32 4. download tomtom home and run it 5. make all upgrades that the tthome sais 6. copy the folders with maps and voices from saved ones 7. if restarts or freeze on logo, open tt as folder and delete the file MapSettings.cfg from map folder 8. say thank you
Apr 26, 2011 | Tomtom One XL GPS Receiver
Can I download another language for my tomtom xl
Hi.
There are several ways to change the language settings on the TomTom One.
If you do a reset using the reset hole, after restarting the TomTom, you will get again the initial setup page. Page 8 will ask you which one is your favorite language for using the TT.
Another way to change TT language is using TT menu to change language. You can follow the step by step instructions given on this page. Click here to open the link.
Regards.
Jan 04, 2010 | Tomtom One XL GPS Receiver
Just got my TTone, confused about when to use the charger
To avoid an eventual loss of power while you are driving and the subsequent unsafe fumbling with the machine, you can plug the TT in the cigarette lighter during your ride. This will supply power to the GPS and recharge the battery.
Alternatively, before going on a trip plug the TT in a USB port of a computer and it will recharge the battery. With a fully charged battery and the car power adapter/battery charger you will not run out of power.
Dec 31, 2009 | Tomtom ONE 130 GPS Receiver
Computor does not reconise my tomtom go 910 satnav says formatting failed computor says usb device has failed
Power on the TT 910 and then press the Reset Button on the base of the TT. It is a tiny hole with a hidden button. use a rounded object, match end or soft pencil to puch the button. Then reconnect it to the PC and the PC will see the TT. Note that you may have to reload apps and maps depending on the state of the TT.
Nov 13, 2009 | Tomtom GO 910
Tomtom wont come on
More than likely the negative post on your 910 is not making a contact. This is a known problem for the X10 series tt's. It can be fixed but you have to disassemble the tt to do it. No just replacing the battery won't fix your problem. If it was just a battery problem your tt would still boot up if connected to external power.
Jun 12, 2009 | Tomtom GO 910 GPS Receiver
I was trying to rechatge my tomtom and i cannot
You don't say what kind of tt you have but most have a reset hole on the bottom of the device. Take a paperclip and straighten one side out. Insert the paperclip into the reset hole and hold it for at least fifteen seconds. Your tt should start normally after that. If it doesn't start up you may have the green light of death and nothing you do will get it going again.
Hope this helps
May 01, 2009 | Tomtom ONE GPS Receiver
My TomTom 510 will not hold charge and now cannot be switched on
If you are not bothered about using it on battery your tt should work if you have it hooked up to a external power supply such as the car charger or home charger. If it doesn't work using either of the power supplies then your problem is deeper than just needing a new battery. Check the pins on the bottom of your tt to see if they are bent, or out of place. The most common problem for them is the negative pin on the far left with the lcd screen facing away from you gets bent or is not making contact even though the green light is on.
Hope this helps
Mar 06, 2009 | Tomtom XL 330 Car GPS Receiver
Does car lighter plug have a fuse (no power)
I'm assuming you own a TT.. in which case, yes.. the CLA should have a fuse. I wouldn't recommend replacing the fuse yourself in case you get the amps wrong and burn out your TT. check that the green light on the CLA comes on.. if not, then you probably don't have the CLA in right. Otherwise, you can purchase a replacement TomTom CLA online somewhere.
Jan 09, 2009 | Tomtom ONE GPS Receiver
TT Home does not recognise connection
You definitely need software and maps on an SD card. The TOMTOM will not work without a card inserted. The card will contain MAPS , Map authorisation codes ( to show they are genuine TOMTOM maps bought and paid for ) , POI ( points of interest ), GPS fix data , voices ( for spoken navigation ) etc etc etc. ....................
PLEASE NOTE , TRYING A CARD FROM ANOTHER TOMTOM is very unlikely to work. Each card has an authorisation code that is generated via an algorithm inside each TOMTOM and is device specific.
However , trying a card from another tomtom might produce a diferrent result but still not work , at least this might prove that the tomtom is working OK before you rush out and buy a tomtom card.
Feb 02, 2008 | Tomtom ONE GPS Receiver
Tomtom troubleshooting
My daughter had this problem and it actually turned out to be the cigarette lighter connection. The fuse needed changing and bingo all working well now! Check you have a green light on the charger cable going into your cigarette lighter - if you dont its probably the fuse.
Aug 01, 2007 | Tomtom GO 700 GPS Receiver
Tomtom ONE GPS Receiver Logo
130 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
