Question about Lexmark C750dn Printer
Lexmark C750
Hi I need a diagram of a Lexmark C750 pls
    President:
  • 3,130 Answers
Theres a lexmark c750 service manual on a cd available on e-bay right now as I type It says it will end April 21. GO FOR IT!!! Good luck
Posted on Apr 19, 2006
SOURCE:
171 motor error on C750
make sure the gears is good other change the motor
Sep 09, 2011 | Lexmark C750 Laser Printer
I have several Lexmark C750 and they all have vertical streaks on the right hand side. I have trying to find some type of wear and tear, so I know which parts to order. I examined the color cartridges,...
You may have to clean the ink jets.. go into the software where it manages the print heads. Run it through clean print heads or jets program several times. Then run the realign program and see if that helps.
Oct 04, 2017 | Lexmark C750 Laser Printer
The Lexmark C750 leaves about a 1 inch band of all the colors upon startup. The initial color calibration is leaving the band. Konicas can produce the same problem. The transfer belt is new. The problem...
The problem could be caused by an alignment problem. Please try to do an alignment on your printhead.
http://bitly.com/oXAQuG
If you need further assistance please contact Lexmark Technical Support.
Aug 09, 2011 | Lexmark C750 Laser Printer
Will the toner out of a C760 work in a C782
Color Laser Toner Cartridge is compatible with Lexmark X762E, X762, so it will not work in C782
Lucas
Jul 07, 2011 | Lexmark C750, C752, C760, C762, C770,...
Where is the paper jam when the panel of our Lexmark C750 says "200 paper jam"
Primary: Paper is jammed at the printer input sensor. Open the printer left door to access the paper jam. If sheets have been accumulated to be stapled or offset when the jam occurred, the printer alternately flashes the primary and secondary messages to indicate that all accumulated sheets not be removed during the jam clearing procedure.
Secondary: When this message is displayed, do not remove accumulated sheets during the jam clearing procedure as the printer will not reprint the removed sheets. Also, if the accumulated sheets are removed, the portion of the job printed after the jam will not be stapled.
Nov 03, 2009 | Lexmark C750 Laser Printer
,my copies are almost to light to read, ive only had the printer for a couple of weeks the printer is a lexmark c750 laser
How many pages do you think you've printed?
If this was a brand new printer it might already need new toner. The "starter" toner they give you with a new printer usually doesn't last long.
Jul 03, 2009 | Lexmark C750 Laser Printer
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
I dont have the disk to insatll my all in one x1270
For a Lexmark X1270, initially pls go here, in the Search by Model, pls input Lexmark X1270 then hit "SEARCH". In the next window, pls input your OS in the Select your Operating System, thereafter follow on screen instructions.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 17, 2008 | Lexmark Office Equipment & Supplies
Lost printer setup CD
Try this site since your printer didn't come up from Lexmark, it might be compatible with w820 or c750.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:332:0:0
May 25, 2008 | Office Equipment & Supplies
Lexmark C750dn Printer Logo
57 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
