Open following link for manual.
http://waterheatertimer.org/pdf/Intermatic-et70215cr.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET70
Keypad is explained on page 4.
If you reset timer by holding down reset button and clear button, all programming will be lost.
So it is better to change data instead of clear all data.
Instruction manual says timer displays prompts that guide through steps.
So some steps are automated.
Page 3: Put RUN-SET slide switch into SET position to enter, review, or clear data
Two categories of of data: set-up and programming.
Page 4 suggests that putting slide switch into SET position will display each setting in sequence.
You enter data using keypad, and then okay data presumably by pressing OK button.
To save data, move RUN-SET slide switch to RUN position.
Additional resources:
1) Add a comment and I will respond.
2) Contact Intermatic:
http://www.intermatic.com/customer%20service.aspx
3) Take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Take a moment and rate answer:
