Question about Sony Televison & Video
Thin rose line appear on lhs display
Dear sir,
a thin rose line appears ever on the screen even in on signal condition.pls help us
    Scholar:
  • 42 Answers
Kind of hard to understand your question but i think ive got it.
I believe your saying a thin red line appears going down or across your display.
And im sorry to say that i belive that your screen has lost some pixels due to a possible
drop, hit, or any other ware and tear, even over time, pixels seem to fade out and die on everything.
http://www.flickr.com/photos/53416219@N00/2110489041/ if its possibly something like that but smaller... I would bet to say it is dead pixels and is un Repairable, unless the Lcd is replaced.
Posted on Sep 11, 2008
Do you think it is a coincidence that a thin vertical blue line appeared both times when the analogue to digital signal transition was occurring? After the first tower changeover finished it disappear
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 15, 2014 | Panasonic Televison & Video
Thin horizontal lines on screen
It sounds that the TV is displaying vertical retrace lines along with the picture. There are many reasons for this fault. It will be better to contact any service technician in this case. Gopakumar Gopalan Google
Feb 11, 2014 | Samsung BN96-08752A Y-Main LJ41-05683A,...
Suddenly a very thin vertical yellow/white line appearing on my HP desktop monitor? pls help
Does it appear THE MOMENT you turn the unit on?
If it does, then you will have to run the monitor's self-test function by turning it on with the data cable (the one that does NOT connect to the power outlet) DISCONNECTED from the computer.
If the line still appears, then the monitor is faulty & cannot be "repaired". Usually, the entire LCD module is replaced.
If the line does not appear in the self-test mode, then check if it's connected to an ON-BOARD display adapter (typically found in the back of the machine, towards the middle area, towards where the ethernet cable and USB devices plug in) or a EXPANSION CARD (normally located towards the BOTTOM part in the back of the machine).
If it plugs in to the on-board slot, then the motherboard may be faulty. If it plugs in to an expansion card, then it's the card that may need to be replaced.
Of course, these are merely possibilities, but the most likely failing component here is the monitor itself. Busted display adapters very rarely, if at all, manifest these horizontal or vertical lines and STILL boot up. Regardless if it's on-board or expansion card, a failing display adapter would normally have either no display at all, or it would just simply stop booting up (screen remains dark: no lines).
Aug 12, 2011 | Computers & Internet
Vertical lines appear permanently on the screen
your display is going out you can contact Dell for a replacement.
Nov 01, 2009 | Dell Inspiron 2200 Notebook
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Vertical thin linings on lcd monitor
pull out your memory sticks and reboot with one of the two. if you nonly have one barrow one from some one else
Dec 30, 2007 | HP Pavilion dv4000 Notebook
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Lines in replay
Digital video camcorder are recording signals in very thin line (as thin as 1/8 of a hair.) Therefore, following symptoms may appear if video heads become dirty even a little. If such symptoms appear, clean the video heads with a commercially available dry cleaning cassette. If the symptoms reappear shortly after cleaning, the video cassette may be defective. Stop using the cassette. Video heads may become dirty under the following conditions: (1) When using the camcorder in humid or hot places. (2) When using cassette with damaged or dirty tape. (3) When using the camcorder in dusty places. (4) When using the video heads without cleaning them for a long time. Note: Before you make important recording, clean the video heads and make a test recording first. We also recommend cleaning the video heads after use before storing the camcorder.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Dirty Replay
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Televison & Video Logo
256 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
