Question about Kodak EasyShare CX7220 Digital Camera
HELP MY CAMERA HAS COME UP WITH THE FOLLOWING MESSAGE: E10 REQUIRES SERVICE
    President:
  • 3,130 Answers
Best thing for you to do is call this # and see what the service dept tells ya.. 800-242-2424
Posted on Apr 19, 2006
Video camera problems - Sony Video Camera problem
Error code 94:01 is an internal memory error. If you still get the error after reformatting the card or trying a different one, it's an electronic issue usually used by component failure and requires replacement of a circuit board within the camera.
Jul 12, 2014 | Cameras
I have a Canon SX 30is. When I press the power button, I get an E10 error message, and then the camera never turns on. How do I fix this?
Unfortunately, canon tends to use the same error codes across models...particularly the E10 error code which indicates a JPEG IC error. Basically, the image processor has just given up. I don't know of a way to fix it other than to completely dissect the camera and replace the entire board. Definitely not the news I wanted to deliver but I've seen that error on three separate cameras, and opening up the firmware files for each indicated E10 as being the same error. Any chance its still under warranty?
Sorry to be the bearer of bad news, but I hope that helps!
Oct 23, 2013 | Canon PowerShot SX30 IS Digital Camera
I put newly charged panasonic evolta batteries into my Pentax E10. Took a couple of photos. Then plugged the connector into the computer and managed to transfer one photo into my photos library, but not...
When you reboot the computer, that message should go away. Use an external SD card reader and transfer your photos that way. They are inexpensive and relieves the need to connect the camera to the PC. It will transfer your photos much quicker too
May 15, 2017 | Pentax Optio E10 Digital Camera
Sanyo E10 camera will not format SD cards.
Go into the menu and find "reset"...follow the on-screen instructions. Then, with no card in the camera, find "format" and follow the on-screen instructions.
Jan 28, 2010 | Pentax Optio E10 Digital Camera
Canon 300d gives error 99 and does not work
Try the following diagnosis steps: -
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Nov 28, 2008 | Canon Digital Rebel / EOS-300D Digital...
I have a Canon Rebel XT EOS Every time i take a pic I get an Err 99. I have taken the battery out and memory card for 5 Min. If i do that I can take about 5 or 6 pics before I get that message again. What...
Nov 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Err99 40d canon body only
Oct 28, 2008 | Canon EOS 40D Digital SLR Camera Digital...
300D Digital Rebel is in truble err99
Aug 03, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Error 99
It's English, but try the following: -
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Jul 04, 2008 | Canon EOS Elan 7ne 35mm SLR Camera
Pentax optio E10
Put a quality battery and start it.....
Mar 22, 2008 | Pentax Cameras
Kodak EasyShare CX7220 Digital Camera Logo
56 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
