I cant find my wireless network connection page. were it youst to be, there's now a window stating a error message asking me to use another software rather than it showing the available wireless connections that are available. Also somehow i have disabled my wireless bluetooth and i dont know how to enable it i have tryed pressing ctrl and holding bluetooth button but nothin happens
Hi. I have a Vigor 2910g router. The router is working. Im trying to change the configuration, but i cant access the web page. Im connected directly to one lan port. I type the router IP in the web browser...
These are the general steps to all wireless connectivity.
Click the link below for proper cable connections in setting up your wireless network.
This link also provides somewhat a checklist on what you need for wireless connectivity.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows XP. http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Windows Vista. http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Windows 7. http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Jan 31, 2011 | Draytek Vigor 2910G Dual WAN secure...
I cant figure out where the pin number
Are you trying to connect to the wireless network on a WINDOWS VISTA / 7 computer? Sometimes on the windows vista computer , it will ask you for the PIN number when you try to connect to the wireless network. On the same window at the bottom you will find the option " I want to connect to the network or I want to enter the key manually". If you click on that option , it will ask you for the security key.
If you don't know the security key, then you will need to check the settings of the router. You will need to open the router set up page where you can check all the wireless settings of teh router. If you want, you can also find the PIN on the wireless settings page of the router.
If you are trying to connect any other wireless device to the network and it is asking you for the PIN then you will need to open the set up page of the router and under wireless settings you will find PIN.
Click here for step by step instructions
Nov 03, 2010 | Linksys Wireless-G WRT54G Router
I just set up a new WRT160N wireless router. The PC connected to it works fine. My son can not connect to the wireless connection, even when he is 10 feet from the router. The response is " Unable to...
If you are trying to connect to the wireless network, then first you should know all the wireless settings of the router ( SSID , Security key or password).
If you don't the wireless settings of the router , then you will need to access the router set up interface.
On the set up page of the router you will be able to find the wireless settings of the router.
Once you have the wireless settings of the router then you just need to connect to the wireless network on your computer.
For Windows XP -
In case of windows XP computer you will find the wireless network connection Icon In the bottom right hand corner. right click on it and go to the option " View available networks ". You will be able to see your wireless network. If you do not seethe icon there , then try START ==> Control panel==> network connection. You will find the wireless network connection option.right click and go to " View available networks ".
If you get the message " Windows can not configure this wireless network " , then there is another software utility on your computer which is managing your wireless network. You will need to use that utility to connect to the wireless network. Suppose you have Linksys adapter on your computer , then there must be Linksys utility on your computer which can connect you to the wireless network. if you are not able to connect using that utility then you can switch over to the Windows Utility.
If you get the message " NO wireless networks are found in the range " , Make sure that the wireless switch on your laptop is turned ON. On the laptops there might be a wireless Switch that you will need to turn on. On Some laptops the wireless switch may be the combination of Fn + F2 Or Fn + F5 Or may be different than that. Once you turn on the wireless switch you will be able to connect to the network.
If you seethe wireless network and you tried to connect to the wireless network , some times you will get the message " Waiting for the network to be ready ". That means you might have tried to connect to this network before with different wireless settings . In this case you will need to remove the network from the preferred networks and try to connect again.
WINDOWS VISTA/ Windows 7
In case of windows You will find 2 computer icon in the bottom right hand corner.Right click on it and go to the option " Network and Sharing center ". Once you open the network and sharing center you will find the option " connect to the network " in the top left hand side. Click On connect to the network and you will see the wireless network that you want to connect. If it secured network then type the network key or passphrase and you will be able to connect.
If you get the message " additional log on information required " then you will need to add the wireless network manually.
If you get the message " settings saved on this computer do not match ..." then you will need to remove the network from the preferred network list. Try to connect again.
If you get the message " Press the configuration button ..." , On the same window at the bottom you will find the option " I want to enter the key manually " or " I don't want to configure the network ..." Click On it and it will ask you for the key.
If you see " Enter PIN number " , then at the bottom you will find the option " I want to enter the key manually " or " I don't want to configure the network ..." Click On it and it will ask you for the key.
For MAC OS
In case of MAC OS, you will find the AIRPORT icon the right hand top corner. If you click On it, it will try to connect to the wireless network. If you network is secured then it will ask you for the wireless network key or password. type the key and it will connect you to the network.
If you get the message " error joining the network " and if the wireless security type is WEP, then try to connect to the wireless network again. It will ask you for the network key / password again. Now this time enter $ sign before entering the network key . It will connect you.
Click Here for more info
Jan 02, 2010 | Linksys WRT160N Wireless Router
My vista laptop wont connect through the router
you said it says connected to the network but not oline.
Check the IP address on the wireless network connection.
there might be nay static IP address on the wireless connection.
If yes then set to obtain IP automatically.
Click here for more information about routers
Jan 01, 2010 | Linksys Wireless-G WRT54G Router
How do i turn on the wireless function on my router
For Windows XP -
For MAC OS
Dec 22, 2009 | 2wire 2700HG-B Router (2700HGB)
How do you set up the wireless
For Windows XP -
For MAC OS
Dec 19, 2009 | NetGear WGR614 54Mbps Wireless Router...
The netgear works when plug it to netgear to compter bt by wireless it dose not work what do i do
For Windows XP -
For MAC OS
Dec 13, 2009 | NetGear WGR614 Wireless Router
Wireless connection for Win 7
For Windows XP -
For MAC OS
Nov 25, 2009 | NetGear DG834G Router
IE is not responding
Hello guys
You can get the driver software from
http://support.dlink.com/products/revision.asp?productId=DWL-G510
If this solution was any help at all please rate it as helpfull or fixya.
And if you need anything else let me know, you can ask me 24/7 by clicking
on the ask me button, I will ansver in most cases within 24hours.
Thanks and good luck!
Apr 18, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Computers & Internet Logo
David Payne
David Payne
