Question about Philips 42FD9932 42 in. Plasma Television
Picture not coming on
When I turn the tv on I get the ambilight in the rear and the sound but no picture. It doesnt matter what source I am using its just all black. It worked fine the night before when it was turned off.
  • 2 more comments
  • gerrybaer Sep 11, 2008
    The TV is about 3 years old. Its a plasma and has no been subject to any movement or power outages. It has been going black lately for a brief second while watching a movie but the ambilight and sound is never interupted.It would go black and then within 3 seconds it would come back on. In this case I turned it off at night and then came home from work the next afternoon and no picture. Just sound and ambilight. There is no flashing redlights on the bottom left just the green light that indicates the power is on.
    At the risk of sounding like an idiot, what is the "LCD". I have heard of LCD tv's but this is a Plasma TV.
  • Anonymous Jan 17, 2009
    my new 47" ambilight phillips lcd is really getting me down, turn it on then turn movie theatre system on and sky, no picture but sound and the ambilight is ok.
  • Tyson
    Tyson May 11, 2010
    How old is this Tv, and has it succomb to any Abnormal ware and tare? because it sounds like your lcd has died or possibly a bad connection to the board.
    Scholar:
  • 42 Answers
Sounds like if its flat screen the lcd went out. The flickering was the screen having to reset itself. Try un plugging it for 40 min. and trying it again. could possibly re-set it again but 90% chance the Lcd is out. if its not lcd and its rear projection the the projector has died.
Can be replaced for about 1/2the price of a new one today.
Good luck
Posted on Sep 11, 2008
  • Tyson
    Tyson Sep 11, 2008
    SIr you don't sound remotely idiotic, i apologize for not explaining,
    Definition of LCD. LCD (Liquid Crystal Display)
    Explanation.
    The Lcd or Plasma Screen is the glass insert you view you picture on,
    and is made up of tiny little light bulbs that produce a picture.
    Lcd is just a short term for the screen, thus i was suggesting
    you purchase a replacement screen identical to the one you own,
    removing the defective equipment and placing all electrical components
    not included in your replacement such as the Green driver boards that
    are the memory of the tv and its brains on how to produce the picture.
    I should place this WARNING though, to inform you also, if you
    yourself preform any replacements or modifications to this tv in anyway
    not authorized by your dealer you will in fact Void any warranty.
    The diffrence between a plasma screen tv and the bigger rear projection is the
    display method. Lcd has combined the projection part directly into the screen,
    rear projection projects the image onto the screen similar to how a camera takes photos.
    I hope this helps you understand sir, and i appologize again for the short terms.
    Good Luck
    And thank you
Philips 32 Ambilight PF 9986 TV Picture Problems - Fuzzy & Loss of Picture
What are you using for signal to the set? (Box?) and how are you connected? (HDMI?)
If HDMI try going Component
It may be the box/HDMI hook up causing the problem.
Mar 15, 2012 | Televison & Video
Philips widescreen flat TV model #50PF9966-37 50" plasma, as the tv warms up a loud hissing sounds comes from the back. The hissing sound does not go away when you mute the broadcast sound. when you change...
From what I'm seeing online, the bulbs in the Ambilight may be the culprit. I also read that a firmware upgrade could fix the issue too. There was also a recall of some TV's with that issue, so I would check with Philips about your model and serial number and see if your TV was included in the recall. If you raise enough cain and threaten to never buy from them again, they may get your set fixed for you... even if the warranty is up!
Good luck and please post feedback!
Oct 10, 2010 | Philips Televison & Video
Hi I have a Philips 32inch ambilight TV about
No a lot of HDMI does NOT send the sound signal through the HDMI cable & must be run AV to AV, the RED WHITE & YELLOW plugs Color to color for RED & WHITE, the YELLOW is Composite Video. . The SCART should indeed have it "All in one" however that signal is only RGB, or Composite Video, a lower quality, than HDMI. Just use HDMI & AV. you'll be all good.
Feb 06, 2010 | Televison & Video
50 in philips hd plasma with ambilight model number 50PF9631D/37
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
Sep 04, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Tv turns on for about three seconds and then turns
here's a simple test, tap the unit several times and see what happens.but, whatever happens, call a tech,it has already faulty components inside.
May 14, 2009 | Mitsubishi VS-60111 60" Rear Projection...
No sound
There are two quick things to try:
1) The TV's speakers may be turned off. To turn on: Press MENU, select "Sound Settings", select "Internal Speakers", then select "On" (as opposed to "Off"), and then EXIT.
2) The Sound source may be set to PIP (picture in picture) instead of Main picture. In that case press MENU, select "Picture", select "PIP", select "Select Sound", then select "Main" (as opposed to "Sub"), as the source of the sound, and then press EXIT.
Whatever PIP is set to may not even be connected to the TV so there would be no sound.
The terms and menus used here are from Samsung so they will be different from yours but the concept is the same.
Good luck,
Techjoel
Apr 26, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Philips 42FD9932 42 in. Plasma Television Logo
197 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
