I've had this receiver for about 5 years, and I like it a lot. It didn't see much heavy use over the years, just mild, on mild volume levels.
Recently after moving the receiver to another house(I was carefull and don't think I bumped it), the output to speakers on the right side stopped working(both on the A and B speakers), I narrowed it down to the receiver itself, since the problem did not transfer when switching cables or speakers.
Anyone seen this before? is this something that can be fixed easily? what am I looking at?
Thanks for any help.
Comments:
Apr 25, 2006
- I meant it didnt switch the side of the defective output.
thanks
Apr 29, 2006
- Balance. Never underestimate the (ridicously)obvious.
When you say it didnt switch when changing cables?? Well if you have no output on the right speaker and you put the left speaker on and still had no output then its your speaker as the problem should have switched from right to left if the problem is in the reciver. Now you could check and see if there are any bent control shafts as this is common durring a move and that would account for the problem or there are internal speaker fuse that may have popped out but this ones doubtfull, or the preamp or main amp printed cuircut board has a crack in them?? If you checked all mof these and need assistance with this repair you can go to the manufactures website to see how and where you can send or take the unit for repair. Good Luck technicalsupport@nakusa.com
I have an older model..TX-8511...which i did not get a manual with. A great ole girl! Question...
(More)
I have an older model..TX-8511...which i did not get a manual with. A great ole girl! Question is..is there a way to adjust the output sound other than jst the bass,treb buttons...Thanx
i have an nakamichi av 500 receiver (which i love) and have been looking in ebay to find a nakamichi...
(More)
i have an nakamichi av 500 receiver (which i love) and have been looking in ebay to find a nakamichi cd player to be used with it., and while there are a few different models for sale. i cannot tell which ones are more compatible with my av 500 nor can i tell which might be the best..or better than others.
I've had the AV-500 for several years, but not until today have I tried to use it in the surround...
(More)
I've had the AV-500 for several years, but not until today have I tried to use it in the surround sound mode. All channels work, but is there a way to adjust each speaker individually? Right now the center speaker is way louder than all the rest. With the new, different receiver in another part of the house I can adjust the speakers individually. I can have the left rear, or right front three times louder than the rest if I want. But I can't seem a way to find how to do that on this particular model.
I have a Nakamichi av 3s,It's were good sound before,but that nealy i see it's sound of right is not...
(More)
I have a Nakamichi av 3s,It's were good sound before,but that nealy i see it's sound of right is not good.I have try on the other speakers,but it's still the same. PLS get me some information about it .thank so much
