Question about Pioneer MEH-P5000 MiniDisc Player
Sound stops my stereo is a panasonic cq-df583u but mabe you can help me anyway.My sound quits if i start turning volume up not even to the halfway point then if i turn it down some times it restarts.but if i turn car off set a minute turn back on it's back on.When on a low volume everything is fine.It's like maybe it might be trying tto prrotect my speakers from an overload.But the volume is not very loud.does not react like a loose conection
You don't have a solid enough GROUND on the amplifier.
Posted on Mar 07, 2009
    President:
  • 3,130 Answers
HHHMMM lets see kinow what could cause that??? Oh I know have you checked the B+ connections going to the stanby power as well as your always on wires?? Could also be a defective speaker or a wire touching in the car becaiuse as the volume rises the more voltage going to the speakers so the more of an overload on the out-put IC. The output IC could also bee defective. My money would be on a bad output ic or a bad speaker or wireing.
Posted on Apr 18, 2006
Panasonic CN-HDS700TD touchscreen car audio system comes on when you start the car but becomes unresponsive after about 10 minutes,shuts down only to reboot again and cycle repeats.please help.
[PDF]Compact Stereo System - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/audio/om/schc25_mul_om.pdf
PanasonicOne that lets the sound come through loud and clear .... This function switches off thesystem (except in radio source) if you do not use the system for .... All phone features can only be controlled by the touch screen of the. iPhone. • The system ...
[PDF]Model: CQ-VD6505U - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/caraudio/om/cq-vd6505u_en_om.pdf
Panasonicwater, is smoking, or smells), turn it off immediately and consult your dealer. ...components of your car audio system carefully before using the system.Missing: touchscreen
Jan 05, 2016 | Cars & Trucks
I just bought some Performance teknique ICBM 500W and installed them and have a panasonic CQ-RX100U 50w x 4 stereo, its on a 91' ford explorer with a factory amp but not sure if connected. when i higher...
I had a 97 explorer came factory with a JBL system, and had a factory amplifier, I had to get rid of the factory amplifier and by pass it to get my new radio to work... my factory amp was in the very rear passenger under the plastic...... mine worked fine until I installed a new stereo (replaced stock one) and because my stereo didnt contain whatever it was to make the amplifier turn on, had to go bypass the amplifier and I unplugged everything I could find on it. Hope this may provide some clues if any
Nov 01, 2013 | Car Audio & Video
I have a Panasonic CQ-C8100U Stereo. Was working fine then the auxiliary jacks stopped working. I Can power down then it sometimes works then doesn't once the volume is turned up past 13. Any...
hi robert. if your aux jack is mounted on the front of the face then i assume you have a problem within the face, maybe a cracked pc board, a switch which has lost its "click" feel, or even dirty gold face contact pins. also make sure that none of the 8 speaker lines is touching/shorting to the ground level. lastly have all your speakers checked independantly. cheers.
May 02, 2013 | Car Audio & Video
I HAVE PANASONIC CQ-C700U STEREO PLAYS ON ALL
are you running the rest of your speakers off an amp? if so, it sounds like you have the amp remote wire connected to the power antenna wire. on some radios there is an amp remote wire and a power antenna wire. the power antenna wire loses power when not listening to the tuner (radio). usuall there is a solid blue and a blue with white stripe. the blue with a white stripe should be amp turn on.
Aug 19, 2009 | Panasonic CQ-C700U Car CD/ MP3 Player
Reset code security for car stereo panasonic cq-vx100u
My friend have in car panasonic Cq-vx 100u them forgot the code. now Ineed a defaul code please sir.
Aug 18, 2009 | Panasonic CQ-VD7001U Car DVD Player
Error saying MUTING LV 0
Hello da_redhot_su,
Make sure that the "MUTE" button on the upper left of the volume control is operating properly. Sometimes a button will get stuck.
If that does not work, there's something wrong internally and you need to take the receiver to your audio dealer for repair.
Hope this helps.
May 08, 2009 | Panasonic CQ-RX400U Car CD/ MP3 Player
Volume won't turn upon my panasonic cq-vad7200u car stereo
this may be a pre amp only deck
and if it is ou have to buy amplifiers to make the speakers work
May 07, 2009 | Panasonic CQ-VAD7200U Car DVD Player
Car Stereo Stopped working
go to the panasonic website and get you manual and read it and it should get you system right again
its free
Apr 06, 2009 | Panasonic CQ-RDP472N CD Player
Stereo Sound
You could start by adjusting the Treble and Bass. The treble is what makes the high notes more nodicable, so if you turn the Treble up you should be able to hear more vocals. The Bass is what makes the low notes more nodicable, so if you turn the bass down you should be able to stop the shaking which I'm guessing is the low notes. On the other hand if you have an aftermarket radio then there might be a Mute or ATT button. Theses are for instant quiet, just repress the Mute or ATT button and it should be fine. I hope I could help.
-Andrew Hawkins
Apr 09, 2008 | Panasonic CQ-C1100U CD Player
MY panasonic CQ-C9700u starts to skip sound threw the speakers when i put it over 25 on the volume but the bass box still goes until 40?
Hi Lando,
Your Sub box gets its signal from the PReamp output. This means your problem stems from the CQ-C9700U amplifier section. You may need service from Panasonic on this one, or a new Head unit. I cannot think of any adjustment that you can do to eliminate a skip sound.
Dec 02, 2007 | Panasonic CQ-C9700U CD Player
Pioneer MEH-P5000 MiniDisc Player Logo
88 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
