Question about Gateway FPD 1830 18.1" Flat Panel LCD Monitor
Gateway FPD 1830 18.1 in. Flat Panel Problem
Display of Win desktop is very dark (barely readable enough to read email) and contrast is not all that great -- EXCEPT that when making new settings (brightness, contrast, etc) the OSD window is just fine (nice brightness and contrast. So it appears the inverter and backlight are fine.
So you end up with a dim screen everywhere but in the OSD window, which seems to be very good.
Is this a logic board issue or something that can be "fixed" with a new driver or some sort of calibration? (This monitor was given to me in this condition and the testing is based on my own computer with no installed drivers for this specific monitor. (My normal Samsung monitor looks great on this system.
Thanks -- John
    Scholar:
  • 45 Answers
Usually in these cases the power supply would be the issue, but you say the OSD window shows up clearly, So the LCD panel is good and the Power Supply /inverter depending on which your FPD has.
FPD 1830 should have 3 boards(logic, Inverter, Power) otherwise just 2(logic, power)
If it is super dim, the problem is the inverter. Or the Power Supply if the inverter is embedded
Otherwise what your issue is the logic board, if you can swap out that part for a good one, Chances are for sure that you will have a spanking new FPD working.
I've worked with these a lot. Im working on one right now.
I hope this helps
Wish you luck
Victorsinferno45
Posted on Sep 13, 2008
Dark Screen
there is a weird possibility that somehow your PC is configured to save power.. that is something you can do on a laptop to save battery..
you can check in the control panel what is the status of your energy options and see whats going up there..
there is also another possibility that it might be the monitor to be malfunctioning... but if after the screen being dark and you enter the options on the monitor and they are bright i doubt its a malfunctioning monitor..
so try to reinstall the monitor drivers and possibly the drivers of your video card if you have one.. but my biggest bet would be the option energy in the control panel
Dec 22, 2007 | Gateway FPD-1930 19" Flat Panel LCD...
How do I Adjust contrast And sharpness
To adjust contrast and sharpness
1. Press osd button (on screen display)
2.Use the up and down arrows to highlight selection then press auto/set button
3. Use the arrow keys to adjust settings
4. When you have finished press the osd button to save and exit
Thank you for using fixya.
Jul 11, 2011 | Gateway FPD 1730 17 in. Flat Panel LCD...
My fpd 1730 moniters brightness and contrast are terrible, and i cant get the controls to work
nonnie707, It is very possible that your monitor's internal or external (lay on floor) "switch-mode-power-supply" has a problem. Prove that your pc is working by connecting KNOWN GOOD monitor to your pc!!! If you are not electronics technician then you will need to question Gateway as to warranty service or possible swapout for a REFURBISHED unit if your unit is deemed as premature failure. May cost $ for swap. READ my FIXYA profile and that of other FIXYA TECH's (buddymc, budmrtn) for more options as to "what to do"!!! Remember, If very strange and weird things start to happen (occur) with "cold-cathode-fluorescent-lamp" backlit LCD display, the first place I would investigate would be the units "switch-mode-power-supply" Good luck with the repair. 12fixlouie
Feb 02, 2010 | Gateway FPD 1730 17 in. Flat Panel LCD...
Message from display FPD 1730 won't go away
press the menu button on screen panel and press exit.
Dec 02, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Computer will power up, but FPD 1730 screen stays dark, says "power saving mode" How to cure??
Its setting problem just fallow this stapes for the same.
Go to Start > Control panel > Power options Properties >
Turn off monitor: Never
Turn off hard disks: Never
System standby: Never
Apply > Ok
After that your issue will resolve.
Thanks
Abhay Singh
Nov 16, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
How to resize the desktop? I cannot see the low bottom part of the desktop
I assume you're running Windows XP? Control Panel --> Display, Settings tab. Change the resolution using the slider. Choose different ones until you find one that works.
Hope this was helpful. If so, please leave a rating!
Mar 10, 2009 | Gateway FPD 1730 17 in. Flat Panel LCD...
Cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
Dec 01, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Dark screen of Gateway FPD 1520
If you can see the screen display an image upon close scrutiny, it could be that the florescent back light is burned out.
Aug 03, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
L13V36 Dark Screen, picture can be seen in bright light.
If the backlight lights up for a second it's probably fine - It lay odds on the display inverter in the screen. Actually finding parts for anything made by gateway may be difficult, however. They do not sell spare parts. Considering the size of the LCD i bet it would almost exceed the replacement cost of the screen to repair it
Dec 30, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD 1830 18.1" Flat Panel LCD Monitor Logo
534 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
