Question about Philips 60P8341 60" Rear Projection Television
Part removal do you have to remove large signal board to remove small signal board? thanks
  • ron davis Apr 20, 2006
    thanks techman
    President:
  • 3,130 Answers
Best thing for you to do is go to Sams Photo Facts and order the sevice manual it is avail as a pdf or an e fact and cost 44.00 then that will assist you in serviceing this TV Good Luck
Posted on Apr 19, 2006
The Audio cuts out for a split second every 20-30 seconds.
Check the small signal boards solder connections. The small signal board is the large green circuit board on the right when looking in the rear ( Has all the inputs on it ) Famous for solder issues on the ITC222 small signal boards.slinteriors_22.jpg
Aug 12, 2011 | RCA D52W19 52" Rear Projection Television
Tip
How to fix a no vertica drive problem.
Your projection TV works but the only visible part is a thin horizontal line across the screen. What happened and how do you fix it?
Your problem is that you have no vertical drive, only a small horizontal line across the screen. In older projection TVs this is usually caused by broken solder joints in the area of the vertical IC and over the entire board. It could also be caused by a bad vertical IC. Let's approch this problem one step at a time.
Disconnect the power. Remove the back cover. Remove the board with the vertical IC which is usually the board with the high voltage transformer on it and it is usually on the right side of most TVs. You can also identify the proper board by looking for and following the wires from the yoke which is on the CRT neck. There should be a yellow, brown, green and red. The yellow and brown are the vertical wires.
Before removing any wires mark them with a sharpie or a label maker. Just make sure that you will be able to reassemble the unit without mixing up any wires.
Usually the board in question is on the right. It will be the one with the flyback on it. The flyback looks like a small cylinder with about 4 large wires coming off of it. They will be red rubber and flexible. One goes to each CRT.
You will need to remove the entire assembly to get to the underside of the boards to solder the unit or replace the vertical IC. Sometimes removing the restraints will allow enough room to flip the board over and do the work without removing all the connectors and removing the board.
Once the underside of the board is exposed, solder all connections on the boards. Be careful not to bridge any connections. Test the unit for proper operation.
If the unit still does not work properly replace the vertical IC. It usually begins with LA followed by 4 digits. It will be in the vicinity of the flyback probably towards the front of the board. The Ic will be attached to a large aluminim heat sink. Make sure that you do not bridge any of the circuits when soldering. Replace the IC, reassemble and test.
If things went well the unit should work ok.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
on May 12, 2010 | Televison & Video
I am going to resolder the flyback, but what is? and where is the small signal board?? And would that need to be replaced or repaired?
I am attaching a picture of the flyback whicch is the large transformer which is on the far left side and has the thick red wire coming out its top. The small signal board is the large green board on the right side with all of the inputs on it. The small signal board is a sensitive board and requires professional tools (Chipper Check interface )to diagnose and repair. But the flybacks are famous for failing. the flyback is circled in the picslinteriors_15.jpg
Jul 24, 2011 | RCA R52WH73 Projection Television
Philips 60pp9202 has volume but no picture
You may a bad ground on the power supply board,and this may include a vertical IC that is having problems. Another thing for me to suspect would be the convergence board is on the fritz. At night sometime remove the back cover and see if you can see the ends of the picture tubes are lit while the TV is on. If they are I would say,yes the convergence ICs are bad. And finally , you may a bad small signal board. This is a small card next to the RCA connections and RF connectors inside this TV. This small signal card is quite expensive to replace. Also, this is my first calculation of errors on this unit. The last answer is my best guess. You will have to decide if you really want to repair this. Once again this small signal board is expensive. Thanks for asking and show a few hands of support.
Nov 10, 2010 | Philips Magnavox 9P6034C 60" Rear...
Menu keep on & off the screen blocking the view of the screen.
THis is an indication of faulty keyboard on the front of the set. this cuircit board can be replaced. If this is the problem you can remove this small cuicit board and use the remote until you can replace it. also this will confirm the problem. to remove this board you have to remove the bottom front panel then remove the center panel. if you remove this curict board then the menu stops poping up then this indicates the problem if not it will be on the small signal board
Oct 14, 2010 | RCA HD52W59 HDTV Projection Television
Hitachi model 50v71discolorization on the screen
You have a small signal board that needs reworked. Also known as the convergence board. Send off to PTS Electronics.
Sep 15, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Projection TV, Sound but no Picture
If this Tv is a model year 1996 or 1998, It is quite possible your vertical IC needs resoldered. It is located on the small signal board. This board [quite large anyway] is the board on the left. I don't know the location off hand. The IC has seven pins and located on a heatsink, It is a TDA series. Resolder any and all grounds you see. May as well get the Large Signal board [On the right] resoldered. The other problem would be the P I P board, a small board standing up, that can be removed and replaced. But try the earlier first. This is tedious, but will produce results.
Jul 12, 2009 | Mitsubishi VS-5059 50" Rear Projection...
Bios password for dell inspirion 6400
remove the laptop (large battery) then: remove the bios battery (small) from the motherboard wait ten minutes pluf in the laptop reboot then shutdown and reinsert the laptop battery. your code will be erased
May 21, 2009 | Dell Inspiron 6400 Notebook
D56w20
the board comes out through the rear. the board has plastic perimeter clips that have to be depressed into the plastic frame to slowly work that board out after the wires are unplugged from the board and there are also two clips that extend from the plastic frame through that circuit board that will have to be removed. The large red wire has a plastic ring lock under the rubber boot be careful not to break the ring lock on the large red cable. the small wire from the flybcak just gets pulled out with a pair of pliers, its rough but it will pull out of the flyback.
Aug 17, 2008 | RCA D52W19 52" Rear Projection Television
Convergence panel removed with repairman in tow
The zenith part number for the convergence out PWB is 6870VS1531A thats a small skinny, is that the board he took or did he take the large board on the left side of the chassis looking in the rear?
Jul 25, 2008 | Televison & Video
Philips 60P8341 60" Rear Projection Television Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
