Internal speakers not working
Dell inspiron E1505 internal speakers are not working. I hear sound when i use headphones. I checked all diagnostic test, reinstalled drivers, in vol control panel advanced settings its already sp mute button is unchecked. It was working fine till the day i was using laptop, TV and Iron box on single phase of 3 phase electricity. and it got trip ......since then not working
  • 1 more comment
  • Anonymous Jan 22, 2009
    internal speakers not working .. earfones working fine .. pls help
  • Lucy126 Apr 01, 2009
    dell inspiron 1200, earphones work but internal speakers emit no sound. suggestions?
  • Anonymous May 22, 2009
    I have a laptop compaq presario 1200, and since I've had it there has been no sound from the speakers or from headphones or plugged in speakers. I already did the troubleshooting and driver reinstall. I opened up the laptop to see if the speakers were connected. Everything appears to be the way it should. I get a sound icon in the tool bar and it acts like it's playing when I put in a music cd, but still no sound. I even had the system erased and rebooted. I am wondering is it possible for the speakers to be blown? If they were wouldn't the headphones still work? Do you have any idea what is going on?
I'm using a nec versapro va86j. The media can play, but the speakers not working. Help me!
Posted on Sep 11, 2008
Internal Speaker not working properly suddenly. Hearing Ruptures along the voice.
If you have been using your computer with the audio on full you will probably have blown the speaker cones. An easy fix. Add some external speakers.
May 21, 2013 | Dell Inspiron N5010 Black
Dell Inspiron 6400 E1505 audio not working.
Try system restore to straighten out registry to play audio..
Apr 01, 2012 | Dell Inspiron 6400 Notebook
My dell inspiron N5010 's internal speaker is not functioning..but i can hear through my head phones
The problem is in the earphone jack, when you plug headphones into the jack it dis-connects the internal speaker. Since you can hear the sound through the head gear, it indicates the jack is defective and needs to be replaced, or it needs a good flushing of electronic contact cleaner, attach the supplied straw and aim it in the jack and spray, next take the headphone jack and push it in and out quickly, repeat the process three or four times, If this fails the laptop will need to be dis-assembled for continued repair.
Jan 21, 2011 | Dell Inspiron 1525 Laptop
Dell Inspiron E1505 Sound Problem
if u hear on head phones.. so go bios n check the audio settings
Oct 23, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 absolutely no sound anymore
1. remove all external peripherals.
2. use the internal speakers
3. uninstall / reinstall the audio drivers
4. reboot system
5. if still hearing the crackling sound check if cracking sound can be heard only inside windows of even in the bios.
6. check bios hdd if in acoustic mode performance if yes then set it to normal.
Oct 08, 2009 | Dell Inspiron E1505 Notebook
Left internal spkr not working
Try connecting an external set of speakers or headphones, see if you get both channels, if you do, then the speaker assy is bad and needs replacement.
If you only get audio on 1 channel externally, then check all the sound settings in Control Panel (make sure correct speakers are selected and the playback settings are all correct.)
Jun 29, 2009 | Dell Inspiron 1420 Laptop
Internal speakers do not emit sound but I can hear w/ headphones
I have a 700m, so I'm real familiar with the system. I see one of 2 possibilities. The headphone jack has a switch that disables the on-board speakers, if that is stuck or broken, then the jack/switch must be replaced. (Big hassle)
The other is easier to troubleshoot, then connection from the speakers to the MB goes through the Right hinge cover. Take the hinge cover off, check for broken wires (I has one, ***** to splice too)
Jun 05, 2009 | Dell Inspiron 700m Notebook
Muted sound from left speaker, no sound from right speaker
try uninstall/reinstalling audio driver. if it fails contact Dell tech support possibility that the internal speaker is already loose/broken.
May 25, 2009 | Dell Inspiron E1505 Notebook
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
Dell E1505 internal speakers not working
You have verified that the sound card and drivers are working, by plugging in externals. This leaves only the speakers. Check and clean the speaker connections, they will sometimes work loose or get a little dirt/corossion build up. If the connections are good, then you will need to replace the speakers.
Jul 30, 2008 | Dell Inspiron E1505 Notebook
Computers & Internet Logo
1,087 people viewed this question
David Payne
David Payne
