Question about Sony FD Trinitron WEGA KV-32FQ70 32" TV
Cannot get channel 2 clearly
Channel 2 is grainy and distorted sound while all other channels are fine. I don't know how to fix this problem.
  • 4,234 Answers
Normally grainy pictures are a result of poor ground connections, although usually for more than one channel. Check the cable connections first. Otherwise all I can suggest is to have the tuner replaced.
Posted on Sep 11, 2008
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Right channel distorted denon UDRA M7
Hello there, I have the same amplifier and now it has the same problem on the right output. Have you found out how to fix it? Thanks!
Nov 07, 2013 | Audio Players & Recorders
What would be the probable cause of my konzert amplifier av-502 after replacing 2 power transistors npn & pnp in the left channel, the sound is distorted. i'ved checked the voltage across the spea
Check the bias resistors. They can burn out when power amp transistors fail. They will be very near to those two replacements. You can compare any parts using the right channel as a good. Readings and voltage measurements should be the same for both channels. Also the look of the parts. If a resistor is off-colour in the left, but not in the right you know something is up.
Jul 02, 2013 | Audio Players & Recorders
I have a hitachi rear projection tv. Model #51f510. Picture is bright and clear but goes to distorted when you change the channel. If you turn the tv off then on its worse. Then again turn the tv off then...
Try tapping/knocking on various parts of the TV to see it a bad solder joint is responsible. It could also be some component getting too hot or aged to the point of malfunction.
Don't waste any money trying to fix this, rear projection TVs are dinosaurs.
Jun 21, 2012 | Televison & Video
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Mar 11, 2011 | LG 32LD350 32 in. LCD TV
Two or three of the channels start of clear then go grainy or unclear
Is your t.v old. If yes this can sometimes happen. All you have to do is take those channel, tune them BACKWARDS a little and then set the channel as required and then store. Do this for every channel separately.
Apr 21, 2010 | Hitachi 36UDX10S 36" TV
Can you tell the wattage of the onkyo tx 905 not the home theatre model stero only
140 watts minimum continuous power per channel, 8 ohm
loads, 2 channels driven from 20 Hz to 20 kHz, with a
maximum total harmonic distortion of 0.05% (FTC)
170 watts minimum continuous power per channel, 8 ohm
loads, 2 channels driven at 1 kHz, with a maximum total
harmonic distortion of 0.7% (FTC)
180 watts minimum continuous power per channel, 6 ohm
harmonic distortion of 0.1% (FTC)
Oct 22, 2009 | Onkyo M-282 2-Channel Amplifier
With my starview 3 all of sudden my sound is distorted
To get back sound channels ect just select the channel in question press menu,
select installation, select manual scan, click ok on down frequency.
It'll now scan for channels when its finished exit back to normal
tv viewing screen go to the end of your channel listing and the desired channel will be there with sound.
This can be done on any channel with no sound by just selecting that channel following the instructions above.
Hope this helps
Feb 25, 2009 | StarView SV211K 2-port KVM...
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
Crate G60XL
Hey madmedia63
Good old amps these. Fixed a few over the years. I would expect dry solder joints in and about the channel switching. If you got a mate with soldering experience, he da man to help you sort it. Hard to help you anymore without actually looking inside the amp to see what's going on. But that's were I would start at least. Way round it I guess is to use a distortion pedal. Go for a metalzone to get similar sort of distortion. \m/ riff out ;)
Jul 17, 2008 | HHB Radius 50 Tube Amplifier
Sony FD Trinitron WEGA KV-32FQ70 32" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
