Question about Kenmore 15864/15862 Top Load Washer
TOSHIBA WASHING MACHINE AW46S1E
Sir the machine leaks thru the center spindle i have it ripped apart but i cant seperate the washer from the main clutch/brake all nuts are out i hammered out the bearing spindle but it wont budge out there pl help all i need is a schmatic do you have one thanks CAPT MOBIN
  • mobin shahzad Apr 17, 2006
    can any one help me
  • SAMYARBAGHER Feb 02, 2010
    TOSHIBA AW-70VB(W) I NEED AN ENGLISH CATALOGUE BECAUSE ITS INSTRUCTION IS IN JAPANEESE.CAN ANYONE HELP ME?
    Champion:
  • 277 Answers
Hi this will help you http://www.repairclinic.com/0047_11.asp http://www.applianceaid.com/direct.html#agitating there are links to new parts there if you torn somthing in there good luck
Posted on Apr 20, 2006
Pad keeps ripping in center when i wash it
most likely its the size of washing machine making it rip , something this large should be washed in a large commercial washer ,its too small a diameter in the drum to bend a large sheet around without pulling it (ripping ) on a home size washer
Feb 10, 2016 | Perfect Fit White Magic Loft Mattress Pad...
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
How to replace inside tap washer in Australia?
To replace your tap washer follow these instructions or watch the video on this link http://youtu.be/kYHq4Jh2-3Q
How to Replace Tap Washer - Australia
Turn off your main water supply before you start.
Turn tap to on position.
Remove tap bonnet
Remove spindle.
Remove worn washer.
Install new washer.
Reinstall spindle.
Reinstall tap bonnet
Turn tap to the off position.
Turn your mains water supply back on
Aug 02, 2012 | Washing Machines
My washer is leaking when draining very small leak what can i do
Start with inspecting the entire lenghth of the drain hose for any type of pin hole or abrasions that could be the source of your leak.
If the leak seems to be coming from the inside of the machine, take a putty knife or something similar and insert it between the front panel and the top panel that the lid is connected to about two inches in from the edge of the side panels and you should feel a fastener, push inward or towards the back of the machine, you will have to push hard, this will seperate the top and front panels, lift up on the front panel and remove it, now inspect the inside of the machine and try to locate the source of the leak, you may have to run the washer thru different cycles(fill,drain,spin,etc.) to see the leak source.
Pay close attention to the pump area for the leak, this has been a source of leaks in the past, with a plastic pump housing, they have been known to develope leaks by way of holes worn thru the plastic housing!
GOOD LUCK !
Aug 08, 2010 | Maytag LAT3600A Top Load Washer
What would make my washing machine leak water and make a funny noise?
this sounds like the main bearings have worn out (they start to rumble first) when they start to brake up they rip apart the water seals that are between them and the back of the washers drum, and then it starts to leak water, to test them to see if there claped out,,,, open the door and try lifting the top of the drum lightly , if it lifts a bit then drops back when you let go its the bearings going, now spin it by hand and you will here a rumbleing noise or grinding noise, when the washer is running on spin it will sound like the end of the world is coming???? im sorry to tell you this part is not cheep to fix, its 2-3 hours work?
Oct 22, 2009 | Kenmore Washing Machines
Washing machine will not drain
hi there.......the blockage is in the pump housing at the impeller....this will require removing the pump seperating it to remove the blockage...but first..check that the main hose from the tub to the pump is not blocked....
regards Sir Galahad
Aug 18, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Leaking water
thank u for bringing your probl to our notice.
well, for leaking from the washing machine is mostly a directly result of wear n tear of drain gate rubber washer, try replacing the washer with new one, will solve your problem, or else u can give it to nearest serive center, u'll b delt within an hour.
not a major problem to worry sir.
if my solution has helped u, then plz give a vote as a feedback. thank u.
Jul 15, 2009 | GE Washing Machines
Leak under tub
you can try tightening all the bolts but if that don't cure it then the seal would have to be replaced.you have to take it all apart to get the tub out then take the 30 something screws out seperate the two 1/2's and replace the seal.this is kind of a tough job unless you have the room and patiance to do it.
Oct 06, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
2 leaks
I had the same problem, found a gold jewelry chain gone through the machine and was wrapped around the central spindle on top and part way through the main spindle seal, you should remove the agitator first for a look, I carefully pulled mout the chain with no damage to the seal, you may also need to remove the drum. I looks a big job but is straight forward.
Mar 30, 2008 | Admiral AW22 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
831 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
