Question about Brother Office Equipment & Supplies
FAX 2820 machine paper wont feed and small black plastic piece dropped out of control panel. How do I replace this piece
Contacted Brother direct
Posted on Sep 12, 2008
Paper jams in back of machine?
you have an obstruction either a piece of paper between the rolllers or the secondary feed rollers are not turning.... open the machine and follow the feed path ...take a piece of paper and manually feed the paper with the machine in the off position look at the feed rollers then the secondary rollers( usually two small rods with rubber sleeves kissing each other ...if you can look at the sides on the machine( inside the cover) see if the gears ( usually white ) can turn or mesh correctly... if you do not see any obstruction then these rollers are not turning when they are supposed to when you press the print button. 90 percent of these problems are paper jams if no jam something is not activating the feed rollers
Sep 05, 2014 | Brother IntelliFax-2820 Laser Fax
When receiving a FAX or printing a receipt, it repeatedly jams. The paper is found inside the back cover baked into a folded fan shape.
This folded pattern indicates that the jam is being caused by a physical obstruction in the paper path section. I would suggest manually feeding a thick piece of cardstock paper and seeing if you can find the location of the jam, as it is most likely a piece of trapped paper or plastic tab that has come out of its original position.
-David.
Nov 05, 2010 | Brother IntelliFax-2820 Laser Fax
Brother 2820 laser fax machine- problem is two papers are being picked up everytime a fax comes and the reult is a paper jam display. how to solve this?
Somewhere very close to where the paper feeds into the machine, you should be able to find a little piece of rubber. This is the separation pad (sometimes it's made of cork). Clean that, and you should start working again. If it works, then you'll eventually need to replace the sep pad, as cleaning is a temporary fix. You can buy that and the feed roller (they should be replaced together) here:
http://www.precisionroller.com/kits-for-brother-dcp7020/products.html?src=gbps
Aug 23, 2010 | Brother IntelliFax-2820 Laser Fax
I have a Brother IntelliFax 2820 machine that jams repeatedly. A page or two will come through fine and then the others will all jam. Some just jam in the back of the machine and others get stuck in the...
  1. Clean all feed wheels and guides with methylated spirits.
  2. Look for any switch or guide that may be bent or out of place.
  3. Look for any small piece of paper or staple that may have lodged in the paper path somewhere.
  4. Ensure the paper is dry. Not stored in a cupboard in the kitchen or the printer is not setup infront of an air vent.
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
Brother FAX; won't let me do anything - shows date/time/MNL
it sounds like you may have a button stuck in the down position on your control panel. if thats not it, write back. you may have to look closely.
hth,
razors
Apr 02, 2009 | Brother IntelliFax-2820 Laser Fax
We havet he brother inteli fax 2820. teh paper keeps jamming when it is tryong to feed through. We replaced the drum and we are still having the problem. IT wont feed any paper through without jamming
IF YOU ARE HANDY, WHEN YOU OPEN THE FRONT COVER YOU WILL SEE THE FUSER SECTION IT SAYS VERY HOT ON THE COVER IT COMES OUT WITH 2 SCREWS THERE MAY BE PAPER IN SIDE HOLDING DOWN A SENSOR. GOOD LUCK BROTHER SR TECH
Feb 03, 2009 | Brother IntelliFax-2820 Laser Fax
Sharp F0-5700 Fax No Paper (Tray)
Remove the tray out of the copier and look for one next to the feed tires.
Jan 08, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Brother fax machine Fax-2820 MFC-7225N
Hi. Open the document control panel and look in with a flashlight and see if the jam switch is stuck. also look for a small piece of paper that might be stuck in there. The jam is in where you put documents in to fax out. Lawrence
May 08, 2008 | Brother IntelliFax-2820 Laser Fax
Intellifax 2820 plain paper fax
Take it out with the drum unit and make sure the toner is in the drum unit right. If it was ok before you changed the toner then you did something wrong. reinstall the drum and toner after you check it. Lawrence
May 01, 2008 | Brother IntelliFax-2820 Laser Fax
Paperjam
Start by opening all the covers and looking for small remaining pieces of paper if the jam is not clearing out.
Now if it is not feeding. Get a cloth and a soapy cleaner, such as fantastic and clean all the rubber rollers until you no longer get any black or brown substance on the towel.
Let me know if this helps.
If not we can proceed farther.
Dec 12, 2007 | Brother IntelliFax-2820 Laser Fax
32 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
