Question about Lexmark X1270 All-In-One InkJet Printer
Lexmark x1200 all in one
Have installed new cartridges after buying a non lexmark refilled one and now everything seems to be working perfectly EXCEPT the page comes out completely blank. Can you help? I have already reinstalled new black lexmark cartridge but stll wont work.
    Problem Solver:
  • 9 Answers
Lexmark printers do not support refilled cartridges. When you wipe the bottom of the cartridge with a paper towel does anything come out of the bottom. If the answer is yes then I would say that the contacts on the cartridge are damaged thus causing it to not work.
I would recommend replacing the refilled cartridge with a genuine Lexmark cartridge.
Posted on Sep 16, 2008
How to fix a Lexmark E321 problem?
Obviously something is wrong with the cartridge or the chip since it was working before. Try buying a new oem cartridge or even an affordable compatible cartridge online, install it, and I'll bet your problem is resolved.
Aug 24, 2014 | Lexmark E320 Laser Printer
My Lexmark X1270 printer at one time worked, everything was good, then when I put a new color to black will not print any other color or a black color, print only a little pale, almost do not see anything...
Lexmark products work best with genuine supplies. Lexmark does not recommend the use of refilled, remanufactured, or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
You can try to clean your cartridge nozzles using the Lexmark software on your computer. From your computer, go to Start menu > Programs > Lexmark X1200 Series folder > select Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them.
If that does not help, maybe it would be best to replace your supplies with genuine cartridges.
I hope this helps.
Dec 02, 2011 | Lexmark X1270 All-In-One InkJet Printer
How can i refill 28 & 29 ink cartridges of lexmark z1320 inkjet printer
You can get a refill kit at walmart, but you can only refilled 2 or 3 times before the cartridges are considered to be non-usable anymore, and don't hold pressure or leak.
I would recommend using genuine new lexmark cartridges on lexmark printers for maximum performance and reliability (and quality) even though it is more expensive.
That's what the manufacturer recommends.
Good luck on getting new cartridges installed on your printer.
Jan 13, 2011 | Lexmark Z1320 InkJet Printer
Lexmark X4530 left cartridge incorrect
You must upgrade your firmware on your printer.
Lexmark has a technical support bulletin :
Cartridge Numbers 23 and 24 Are Not Recognized on X3500-4500 Series Printers
Jun 06, 2009 | Lexmark X5470 All-In-One InkJet Printer
Ink Cartrdige Won't Print
it is because the cartridges are non refillable..... they have a memory chip in them and can not be refilled except by lexmark thru their recycle center
Mar 22, 2009 | Lexmark X5650 All-in-One InkJet Printer
Lexmark x3550 18C0032 ink cartrage set up.
The 34 and 35 cartridges will work. You can also buy a 23a or 24a from and you can refill those.
Feb 12, 2009 | Lexmark X3550 All-In-One Printer
Lexmark 3500 wireless
I have put in genuine Lexmark ink catridges but an error states incorrect cartridge can anyone help.
Aug 03, 2008 | Lexmark X3550 All-In-One Printer
I just refilled the cartrige, but it says the ink is low, My printer brand is Lexmark2400.
You may have a non refillable cartridge.
Lexmark has an interesting development with their inkjet cartridges which they began some years ago with toner cartridges. A court decision required Lexmark to allow their cartridges to be refilled. However, Lexmark would naturally prefer that you only buy from Lexmark. Thus, Lexmark has developed the following system:
  • Lexmark offers for sale two different versions of the same cartridge:
  • The regular version (#23, #24, #28, #29, #41, #42) is not refillable. It is the "Return Program" or "Prebate" cartridge. Supposedly, when you buy this cartridge you agree to return the empty cartridge to Lexmark. In return, Lexmark gives you roughly $5 off the retail list price of the cartridge.
  • The "A" version (#23A, #24A, #28A, #29A, #41A, #42A) can easily be refilled. However, the price of the cartridge is roughly $5 higher than the regular version, so most people unknowingly buy the regular version.
Jun 23, 2008 | Office Equipment & Supplies
X5470 Lexmark printer
Lexmark and Dell use a sensor in the cartridge to sense a low ink level. Once the sensor has been activated, you cannot reset it. The printer should work fine except for the fact that you'll have to override the "low ink" message on your computer.
Manufacurers don't make money on printer hardware. All the money is made from ink replacement, so they make it as difficult as possible to use anything other than the stuff you buy from them. Some (HP) put in chips for an "expiration" of the ink/toner. Go beyond the expiration date, the thing won't work.
May 13, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Anyone else having this problem with Lexmark x1200 series?
Lexmark says that you have to use only new lexmark ink packages. You can not use ones that are refilled. Also you can not only use the black cartridge to print. You must have both in.
Mar 22, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
113 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
