Question about AcerView 78ie 17" CRT Monitor
Help on monitor repair
MONITOR REPAIR HELP Hi I would like to appreciate for your help I have got an Acer monitor model G781 CRT Type its switching power supply is not starting 300 volt supply is ok , Q602 (2SK1940 )& ic 601 (UC3842)have been changed with new one, voltage on pin 7 of ic601 is 12-15 volt(flactuating in between ) it should be 16 volt to generate Vref (5volt)on pin 8 of ic601 to start?!capacitor c626 have been replaced , but still does not start!& the fault is still unknowen ! Your help will be usefull.
  • 1 more comment
  • ALI HEYDARI
    ALI HEYDARI Apr 17, 2006
    HELP REQUIRED !
  • ALI HEYDARI
    ALI HEYDARI Jun 26, 2006
    Checked output circuitry for short , there was no short .
    As the primary & secondary circuit were checked for active components & suspecxted passive components,this time cheked the passive components very precisely & find out the R627 a 10K ohm resistor , in one end is 10k & the other end is infinity !
    So replaced R627 , & the system is started .
    After replacing IC101 ,Q102 , ZD602 , The finnal component to replace was R627 which is replaced & SMPS started .the finnal check was OK . GOOD LOCK
  • ALI HEYDARI
    President:
  • 3,130 Answers
Have you checked the horizontal output transistor for a short or leakage?? most of these sets will not start up unless the horizontal sweep sends the pulse to the power supply and says start me up!! I would look at bthe drive as well on the horiz. curcuit. If theres a pulsating voltage that means its waiting for something to signal it to work or its missing something.. Good luck
Posted on Apr 23, 2006
What flatscreen monitor is OK to substitute for sanpo alphascan 520?
Hi. Almost all the crt type monitors should work, it's flat screen monitors that seem to give computers problems with aspect ratios, and resolution settings.
I personally use an NEC AccuSync 70.
It might not be the newest monitor in the world, but the colors are crisp, clear, and bright.
And It allows a setting of 1024x768@85 hz refresh rate, which works great for my games.
As far as flat screens, I would probably go with an Acer, or a Dell monitor, as these two companies seem to have better quality from their monitors than most other manufacturers.
I hope this helps you out!
Mar 06, 2011 | Sampo AlphaScan 520 (White) 15 in.CRT...
My desktop monitor won't work. Yellow light is on, and it goes into sleep mode.. I can't access my desktop or anything, because I have no screen :( Have unplugged and replugged it from the computer and...
mountainmom, Always state make, model number, and TYPE of unit. Is it a big old CRT type or is it a LCD monitor? Need more information. What is the "date of manufacture" from rear label on monitor. 12fixlouie
Aug 27, 2010 | Dell Computers & Internet
No display
According to the model type, it has likely reached the end of its service life. It would cost a great deal more to have it repaired than to replace it. Here is an example of an inexpensive alternative in the new market ( http://www.walmart.com/ip/Acer-ET.LBF09.030/5013901 )and there are thousands of used lcd monitors available from places like Ebay.
Aug 20, 2010 | AOC 5 En 15" CRT Monitor
What is the rate of 20
Hi, this site will get you a good ideal for Monitor prices, by size; there is a wide selection to choose from, aswell the type you are interested in. "If this helped, rating it is appreciated, thanks." http://www.officedepot.com/a/browse/monitors/N=5+10058/?cm_mmc=360i-_-MSN-_-MSN_Monitors_General_MSN_Monitors_Brands-_-acer_monitors
Apr 03, 2010 | Acer Computers & Internet
Monitor not working
If this is LCD monitor, The power supply of you LCD need to be repair.Ask technician to fixed this power. LCD monitor need to epen and replace defective parts
Jul 26, 2009 | Computers & Internet
Brightness problem
try changing all electrolytic caps in the horizontal circuits
Aug 28, 2008 | Boundless Technology Tatung VM 9AF 9" CRT...
Brightness sometime too light and sometime too dark
I would say there is a problem in the horizontal / high voltage section, but I have no information on this model.
Aug 27, 2008 | Boundless Technology Tatung VM 9AF 9" CRT...
How to repair
MY SUGGESTION IS TO BUY A REPLACEMENT MONITOR AN LCD BECAUSE IT USES LESS energy about 50% less and at a low voltage.
YOU PROBABLY CAN FIND ANOTHER RELAY AND CAPACITOR ONLINE OR AT A TV REPAIR SHOP electronics supply warehouse BUT IF THESE COMPONENTS WENT BAD
OTHER COPONENTS MAY BE BAD ALSO AS A RESULT OF THESE HAVING FAILED SOMTIMES RESISTORS,DIODES AND TRASISITORS LOOK GOOD VISUALLY BUT ARE NOT.
Save your self sometime and money by getting a new lcd monitor
even if you repair your monitor its still old if you replace this mointor with a new one you elimiate all risk because a new monitor will have all new parts and a warranty and save money on your electric bill because it takes less power to operate.
Jan 16, 2008 | Acer AC711B 17" CRT Monitor
MONITOR REPAIR HELP
The mains switch is a weak link on these, check this first. Also 1 of 2 33K 2W startup resistors in PSU goes o/c, check with DVM or if you have very high volts on main primary res cap this usually indicates a 33K has gone - change both. I've also had a small TO92 transistor hanging off the UC3842 failing causing no startup. A s/c HOT normally causes a blinking LED. note that AC cap IS charged, DISCHARGE BEFORE WORKING ON IT! Did you check for shorts in the secondary side of the p/s, horiz output? If there are none , look for the switching regulator. Check the support components. I've seen these with open solder connections on the coils in the PS due to that abominable glue they use...you'll see signs of burning/arcing on the inside of the cabinet, too. Good luck
Apr 09, 2006 | AcerView 78ie 17" CRT Monitor
AcerView 78ie 17" CRT Monitor Logo
145 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
