Question about Shure Beta 58A Professional Microphone
Shure beta 58
I scored an old beta 58 but the 3 pin connector was missing. i bought another one but i don't know which wires to connect where. plus there are only two wires, is that right? I'm a bit of a noob but I like to try things myself :)
Solution #1 by Abrsvcs is in error. I use a Beta 58 and it is not a condenser mic and does not require phantom power.
Posted on Nov 09, 2009
  • Donald Matz Feb 09, 2012
    You are correct.
    You are Correct.
  • 4,234 Answers
Benimur, you are correct, except that the Beta 58 is a condenser mic that required phantom power. In that case all 3 lines are used. Included below are the connections.
Dan
Posted on Sep 11, 2008
  • ABRsvcs Sep 11, 2008
    Somehow the diagram didn't make it... The connections are as follows:
    Pin 1 - Ground
    Pin 2 - Blue
    Pin 3 - Red
    This is not true. All of the Microphones in Shure's SM series are dynamic microphones and do not require phantom power.
  • 122 Answers
The red wire onpin 3 the blue on pin 2 and the pin 1 connect to the body of the mic trhu the holding screw (put a small wire to connect and solder!
Posted on Jun 04, 2010
    Brigadier General:
  • 6,966 Answers
Almost all microphones (except for 2 way radios) uses a 3 pin XLR jack and plug as shown below.
Their pinout would be:
where:
  • Pin 1 - Mic ground;
  • Pin 2 - Mic hot;
  • Pin 3 - Mic cold;
  • normally pins 1 & 3 are shorted.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Close, but no cigar.
    XLR cables are a balanced connection. You should never send signal down the ground conductor.
    NOTHING should be shorted.
  • 2,794 Answers
You need an XLR wire to plug the mic into. What are you trying to plug the mic into?
2 Suggested Answers
  • 13 Answers
SOURCE: shure beta 58
red pin 2
blue pin 3
case (ground lug) pin 1
Posted on Nov 30, 2008
How to open a shure beta 58 microphone?
To open a wired Shure Beta 58, unscrew the handle at the mid point. A new cartridge from Shure includes the upper part of the handle.
The Beta 58A is different.
Jun 19, 2014 | Shure SM58 Professional Microphone
Which pins do I solder the red and blue wires on the xlr jack of a beta 58? they came off and I need to re0connect.
The wiring is in the User Guide. If you no longer have the User Guide, you can download it from the Shure website.
May 30, 2010 | Shure Beta 58A Professional Microphone
Shure 58 when plug it has no sound
First i would check the cable. If cable seems good I would buy some contact cleaner and try cleaning the xlr pins on the bottom of the mic. Last i would take the set screw out of the side of the mic and carefully remove the xlr assembly. There are 2 wires connected to that and not a whole lot of slack so be careful. Basically make sure they are still soldered on.
Mar 27, 2010 | Shure Beta 58 Microphone
What holds the 3 pin connector in the bottom of a shure bets 58? it won't stay in...How do I secure it?
there is a small screw in the side of the xlr connector and a small hole in the body of the mic.put everything together until you see the screw thru the small hole.tighten the screw clockwise and the job done!
Jan 06, 2010 | Shure Beta 58A Professional Microphone
Where can i get my shure beta 58 repaired? I live in Redditch in the UK.
The easiest way to find a service agent near you for your microphone is to contact Shure at the following;
All service and repair issues for Shure, QSC, Phonic, Sound Devices and Radial products are handled directly by Shure Distribution UK. Please contact them at the following for information on service and repair issues:
Unit 2
The I.O. Centre
Lea Road
Waltham Abbey
EN91AS
Phone: 44(0) 1992 703058
Fax: 44(0) 1992 703057
email service@shuredistribution.co.uk
Hope this helps. Please remember to rate my answer.
Many Thanks
Jul 13, 2009 | Shure Beta 58A Professional Microphone
Beta 52 not working, need wiring solution
I'm not positive that this is correct as the internal connection diagram isn't included in the manual but Blk= pin1, Blu= pin2, Red= pin3. Hope thats right. Shure gas lots of info on their website www.shure.com
May 22, 2009 | Shure Beta 52A Professional Microphone
Shure SM2 Headset/Mic wiring
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Jan 02, 2009 | Shure SM2 Professional Headset
Shure beta 58
red pin 2
blue pin 3
Sep 11, 2008 | Shure Beta 58 Microphone
New cable for my Shure Beta 58A Professional
It could be the wiring in the 1/4" jack in your amp. Check the metal contact plates on the 1/4" jack in your amp and see if they are getting contact to the jack. Sometime they get bent.
If the XLR end of the cable can be serviced, check the ground connection to the cable and see if its good.
Jul 16, 2008 | Shure Beta 58A Professional Microphone
Shure Beta 58A Professional Microphone Logo
1,378 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
