Need manual for LG Plasma 42PX4DV-AA
I lost my manual for my TV.
Please help
LG 42PX4DV-AA
will not find channels digital 7, 9, 10
Posted on Oct 17, 2008
The LG 42px4dv-aa States that HD service is not available surely this tv has HD
Your TV is telling you that the network cable company or free air is not broadcasting their programs in HD. Just because they have didgital programming doesn't mean that it is HD programming.
Aug 20, 2010 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
42 inch LG Plasma TV Lost Picture
Hi it sounds like it has had an elctric fault like a resistor failing.
The click you heard would be a internal switch that cuts off the elctric supply to the screen to stop furthe damage hapening.
It could even be something simple like a bad solder and in that case will need locating and resoldering.
How old is the telly and how often is it used.
When you switch it off leave it off for about an hour then try again if you have allready done this then it probably is a blown resistor are you sure nothing has been pressed on controll have you tried seeing if you can acess the menu screen via the remote and see if that comes up on the screen let me know ok
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
LG 42PX4DV
Here you go fella, i had the same problem! Enjoy:
LG 42PX4DV Sky Code is: 0206
Dec 20, 2008 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Getting a HD Picture on MY LG Plasma
Have you made sure the box is set to send a HDTV signal to your LG? Example 720p, 1080i, or 1080p? You usually have to set the resolution in the v+.
Feb 29, 2008 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
I have an LG 42" 42PX4DV Plasma, keeps resetting itself.
Do you use a regular antenna, or cable/satelits tuner?
I use only satelite tuner, and had the same problem on a differnt TV. I solved it by connecting a regular antenna (actually just a piece of cable) and go through the search and store routine once. Then the TV remembered that it was configured. Before that it thought it was "fresh out of the box" every time.
Nov 26, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
LG 42PX4DV 42" problem
Aug 15, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Lg 42PX4dv PC connection
I think the problem is the screen resolution and size of your pc is not matching the resolution size of your tv or is not compatable at the size you have it on or you may have to change to 4:3 ratio from widescreen. In your manual it will tell you the resolution sizes that you tv uses. You would probably be better also using the VGA to DVI lead, thats if it came with the tv (it does in the UK) as it supports higher wide screen resolution, whereas VGA will only support 1024 x 768 or there abouts.
May 19, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Lg 42px4dv - speckly screen
I had the same problem with mine, LG techs came out to my place and upgraded the software and the problem went away. I had mine for nearly a year when it started, supposedly is it quite common. Anyway, dont worry too much about it as easily fixed. I have been very happy with my TV and have used it everyday for 16 months. Just want a higher resolution TV now.
Mar 30, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
LG 42PX4DV-AA query
Sorry to tell ya that the high pitch tone is a very common complaint ,mostly from our lady friends.. As their hearing range is alot more sensitive then their male counterparts. The "singing Coil" problem is nothing more then a loosely wound coil or deflection yolk and even sometimes even the HI voltage transformer. There are a few tricks to try to MINIMIZE only!! The singing of the coils. Such as siliconing the coils . Sticking wood pieces in between the coils or tranformer bases. But the really only way to eleminate this problem 100% is to replace the parts thats singing. And this is not a job for the handi-person.. Theres always a hi voltage issue thats present even when a tvs unplugged!!! Please seek a quailified service tech to assist you inj this nissue. GOOD LUCK
Jun 27, 2006 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Televison & Video Logo
933 people viewed this question
Top Televison & Video Experts
