Question about Electrolux Washing Machines
Model number w355h showing 03e error code at start of cycle.
    Problem Solver:
  • 8 Answers
Have you looking in your manual, sometimes it tells you how to solve the problem, with certain codes, good luck.......
Posted on Sep 11, 2008
Showing a 1E error code
You need to post more info like a model number
Aug 29, 2016 | LG Dishwashers
How can I fix the error code 019 E on my Eloctrolux washing mashine W355H
You probably need a new board, but why not call the local parts supplier and tell the guy you're getting an 019 and he should be able to get you started. Just every now and then you may get around, but more than likely your will need to replace the board.
Mar 24, 2015 | Electrolux Washing Machines
Why would a whirlpool duet sport model number WFW8300SW05 starts fine stops during cycle. No error codes door locked red light on water in machine.
you have a plugged or partial plugged drain pump for sure. maybe there is a 20 stuck in it this time! easy to find just follow the drain hose back and you will find your pump.
also could be the cycle your using has a bad area in timing cct. check a different cycle like the delicate cycle and that will confirm pump or cycle
Jun 10, 2014 | Washing Machines
SAMSUNG J1253 ERROR CODE 4E
Did you leave out the complete model number?, If you haven't yet check your water supply, If you changed to or have the auto stop flood hoses some washers cause them to activate.
The wires may be disconnected on the water valve(s) or a valve went bad or the main board went bad, You can use a meter to check that there is voltage going to the valve(s) when you start a fill cycle, Also some washers use a flow meter that checks water flow.
May 03, 2017 | Samsung Washing Machines
ASKO D1976 model. We have a F2 error message. Water has now been drained but we are unable to remove error code or have dishwasher return to normal cycle
Display shows an error code. Do the following:
1. Unplug washer or disconnect power for one minute.
2. Plug in washer or reconnect power.
3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
May 27, 2011 | Dishwashers
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Keeps stopping during wash cycle
Hi Kathy,just read your posting.When the machine stops during the cycle does the machine beep and show an error code?Could you confirm the model number of your machine.Now if you have an LCD screen on your machine the fault code will appear in it but if you have no screen then the error code will appear as lights .These lights will be a row of 8 lights.Starting from the left to right which lights are on when the machine is beeping.Is it the 2nd and 4th or the 1st and 7th ---etc---?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Sep 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Dishwasher won't start, turns on but no display
1: Defective door lock switch
2: Defective electronic control board.
Get model and serial number of machine, enter model number on search engine and seek same like conditions. You should find solution to problem, or place model number here for me to correctly tell what is wrong.
Oct 01, 2009 | Dishwashers
Kenmore model number 110.84836201 after you start it, it shuts off in about 2 minutes and show and error code E1
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
Aug 05, 2009 | Dryers
2H accures in digital read out. NO Cycles start, just a humming
Do you own an LG LDF6810ST dishwasher? If not, please reply with the manufacturer name, model and serial number.
Are you saying that the display that normally shows the time is displaying an code of 2H? On an LG, that means 2 Hours, (120 minutes) and is not an error code.
On an LG with a symptom like this, I would arrage to replace the main processor card (PCB). You would be getting an error message if the motor (wash or drain) had failed.
Mar 30, 2009 | LG LDF6810ST Stainless Steel Built-in...
Washing Machines Logo
370 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
