Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
WRITE PROTECTION ERROR
Solution for write protection error in flash drive and i cannot format flash drive
  • 1 more comment
  • richardcuenc Sep 11, 2008
    i cannot access or format my flash disk
  • manlogle Sep 11, 2008
    No puedo formatear una memoria DT Mini Fun Kingston de 512 MB, me da un mensaje de "Protegida contra escritura"
  • ketanindia Sep 18, 2008
    my 32 gb pen drive not formatted. it shows Raw file. when open it ask for formatted, but not done.
When i pluged the usb it shows ,but the space on it is 0 bytes.
Posted on Sep 15, 2008
How to fix a write protect usb flash drive
make and model? usualy has a switch or jumper if it has write protect
How To Fix Write Protection Errors On USB Stick
Jun 03, 2015 | Electronics - Others
My Memorex USB flash drive is write protected
t seems that your flash drive has some bad sectors since normally that's the error message you get when that happens, try to format your drive under disk management.
Note: your files will be erased if you format your flash drive.
If formatting your flash drive does not solve your problem I will advise you to contact Memorex technical support for better assistance, you can contact them at 1-877-363-6673
May 19, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
Write protected error
IN THAT FLASH DRIVE JUST CHECK FOR ANY SYMBOL DAT A LOCK MARK AND MAKE SURE THAT IT UNLOCKD BEFORE U PUT IT INTO YOUR COMPUTER
Apr 16, 2010 | Electronics - Others
I am having the samsung SVO411N pen drive it is not formattting and showing error of write protection so how to remove it? while formating it gives the error to remoe the protection from volume in...
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format pen drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Feb 07, 2010 | iLO (2 GB) MP3 Player
Windows was unable to format my flash disk
It seems that the card is bad. Try to format the card on a different machine to rule out your Windows formatter.
Aug 19, 2009 | Dell Inspiron 6400 Notebook
I have 1 gb iball usb flash drive & it is not formatting
Is there a write protect switch on the drive?
In Windows XP, right click on "My Computer", choose manage. Go to Disk Management and find the drive in question. right click on the drive for more formatting options.
Jun 21, 2009 | Computers & Internet
Flash drive write protected? can't add files
This seems to be the problem of most of us these days and some of our readers who wanted to know the methods how they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
Jun 01, 2009 | Kingston 2GB Secure Digital Memory Card
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Remove Write Protection
Solutions:
Update 1:
For that:
May 18, 2009 | Kingston 4GB Secure Digital High Capacity...
Windows was unable to complete the format
sir
u dont need to buy a new one. You can download file shredder from here . do following things :
  1. download and install file shredder
  2. shred all the files which are in pendrive(after shredding u will not be able to recover them)
  3. then try to format it .,
thankyou for using fixya
dont forget to rate the solution
have a nice day
Mar 12, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
263 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
