sorry, i must have messed up. I have this tv and there is no picture or sound. The indicator light blinks constantly. This all happened when i was just flipping channels and the unit just shut off.
On a Jensen tv could be made by NEC Sharp?? No picture to see . But if its a NEc type you could have an over heated power supply where it will take out the stg30130 regulator IC because of a couple of small choke coil You will see them as they look like small over heated resisters on the output of the main power supply. Its this problem or if you have been haveing intermittant sound ,color, video, vert sweep or sync then the Jungle IC socket is the problem cause have a while of living with one of the above problems the set will go dead. This type of repair I think would not be one for a do-it your selfer. Now theres nothing wrong with experimenting or nothing wrong with a do it your selfer But all im saying is that the power supply in this set is not one you wanna mess with unless you know about such things.. Good Luck
Was this solution helpful? Show your Appreciation by rating it:
