Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Error code Bosch washing machine error code E-13 ?
  • Anonymous Mar 01, 2009
    The washer is flashing E:13 and the door is locked. I turned the washer to off, then off again and the door unlocked. The clothes are sopping wet.
    Genius:
  • 1,239 Answers
Hi sir one of these problem will be there 1 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
2 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
3 - No mixed fill. It is likely that the water is not turned on at the taps.
4 - Check the water supply, inlet valve and hot and cold hose connections.
4 - A fault with the water heating has occurred.
5 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
6 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then book a service engineer.
7 - Door not closed properly. Close door firmly at the 3 o'clock position.
E20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing.
thank u............
Posted on Sep 11, 2008
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Error code 141. How can I fix it?
Bosch error code 141 Washing Machines Questions ... - Fixya
www.fixya.com > Forum > Tags > error code 141 > Washing Machines
Bosch washing machines error code 141 related questions and answers. Ask your Bosch questions. Get free help from washing machine experts.
error code 141 Washing Machines Questions & Answers ...
Washing Machines error code 141 questions and answers. Ask your error code 141 washing machine questions. Get free help, advice & support for popular ...
Zanussi Washing Machine Fault Code Reset - iFixit
https://www.ifixit.com/...Washing+Machine+Fault+Code.../34977
iFixitMy Zanussi Washing Machine hasn't been working properly for a while. then it stopped spinning and emptying, then wouldn't go through the programmes at all.
[PDF]TOP LOADER Automatic Washing Machine - you
Dec 29, 2015 | Washing Machines
E36 error code
My Bosch washing machine is showing error code E36 what's the meaning?
Feb 18, 2014 | Bosch Washing Machines
Im getting an error e 13 message and the door will not unlock
error code = bad pump? or just a clogged screen /kinked drain hose?
E:13Er:13 test #P:15Drain pump time exceeded,Faulty drain pump, wire harness, hose
Apr 26, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Hello! My Bosch Nexxt series 300 washing machine is showing a E: 13 error and won't open. I have tried unplugging it but that doesn't seem to help.
e 13 is a door lock error if you are lucky you may have a manual release check where filter is for a red pull release this mechanically activates the door to retrieve trapped washing,if not lock will need replacing engineer visit unfortunately.
Aug 05, 2009 | Bosch Nexxt 300 Series WFMC2201UC
My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Mar 28, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Code E13
For a Bosch washing machine, Error 13 is pumping time exceeded. So, in general, the issue is pump related. Things to check would be if the pump is blocked (it can be cleaned out if you can get the service door in the front panel off), check the wiring connections to the pump, and check the drain hose to make sure it is not blocked.
Feb 14, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
303 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
