No guide for electrolux aqualux 1200 washing machine
I have just moved into an apartment and there is no instuctions for the washer so not sure which programmes to use and advice to wot each letter is thankyou
TRY this Link............. & check they claim the manual....
https://www.2instructions.com/search.php?creference=D2s9mn2k59
Good Luck
Posted on Sep 11, 2008
Hi I have an Electrolux EW Aqualux 1200 in a rented property no manual for the programs would you be able to email me one if available Many thanks rachel
rachel you will find it here if its model number is ew1200
http://www.manualslib.com/download/46075/Electrolux-Ew-1200-I.html
Jun 21, 2016 | Electrolux Washing Machines
I have an Electrolux EW Aqualux 1200. Two weeks ago a sock was stuck into filter. I removed it, switch off/on machine a few times, ran machine empty. However since then machine is spinning only if it is...
9 years a good life for Washing Machine, I can't see why you have this problen , since you cleared it by taking sock out of filter, but expensive to get repairer to look at it , as 9 years old , get a new one . Better than spending money on a repair,
Mar 14, 2015 | Electrolux Washing Machines
My wash/dry cycle has finished but I can't open the door. Is there a manual release please?
turn the dial and listen for a click to release the door. no their is no manual release
Jan 06, 2015 | Electrolux Washing Machines
Free User guide for an Aqualux 1200
I don't know if this helps or not, but Manualsonline.com lists thist one for an Electrolux AW1202 if it is the same machine http://www.serviceforce.co.uk/pdfs/U33052.pdf.
If that isn't it, get the model number off the machine specification plate (usually inside the lid, or on the back) The cutesy name on the front is seldom the actual model number the technicians use to order parts...don't know why they do that. With that specification model number, you might be able to look it up here and get the downloadable manual http://laundry.manualsonline.com/np/usermanuals/mfg/electrolux/washing_machine_product_list
Hope that helps
Jan 21, 2011 | Washing Machines
I have an Aqualux 1200 washer/dryer. After the wash cycle the fabric conditioner compartment of the tray is full of water and the fabric conditioner appears not to have been flushed into the machine
If the dispensers are in their proper spot it is normal for some water to be left in the fabric softener dispenser. When you add your softener add water to dilute it as some softeners are very thick and don't dissolve well especially in cold water
Nov 18, 2010 | Electrolux EW1200i Front Load Washer /...
Washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
Jul 20, 2010 | Electrolux Washing Machines
Electrolux aqualux 1200 water leaking from door
have door gasket changed .....01179512835
Dec 30, 2009 | Washing Machines
Electrolux aqualux 1200 ew
I had a similar problem with a different make recently. After cleaning the filter which didn't seem to have anything in it and rinsing the filters on the in and out pipes I took all the clothes out and ran it empty on two different full programmes and somehow the gremlins disappeared and it works fine now.
Oct 16, 2008 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
814 people viewed this question
Top Washing Machines Experts
