Question about Sharp 25VT-J100 TV
Vertical hold I have a Sharp 25vt-cg6 tv/vcr combo when i turn on the tv i get a 3inch or so linr in the middle of the screen. almost like the control for vertical hold is gone. I've seen this on lots of tv's. So it most be a common occurence. Any help on reparing this would be great. thanx
    President:
  • 3,130 Answers
You dont have enough vertical sweep!! Best thing to check is the vert output device and I think its an IC . BUT before that check the b+ going to that device and see if its low. I will run through a silicon diode right next to the ic. Measure both sides of the diode and if theres a big voltage drop then the diodes bad. Now also these sets are common for the b+ filter cap off thge flyback transformer. Its the voltage line that feeds that diode and the vert output section. Now measure all caps out of cucuit as most will measure good if you dont. Also just for giggles right nrxt to the big IC that has the vert ,horizontal video and sound drive there is if im not mistaking the vert parts start with c4-- or the ic will be ic4-- Its a small cap that will sayc4-- attached to nothing but the ground and one pin of the ic. I've seen this cap cause all sorts of vert problems in the past as its the vert waveshaper capacitor for the vert osc/drive. Good Luck
Posted on Apr 17, 2006
SOURCE:
I have a tv that has line going side to side
The line is horizontal but means no vertical deflection (set deflects picture from middle to top and bottom.
Either bad solder connections at vertical output chip or a bad part somewhere in that circuit.
Jun 16, 2012 | Toshiba 26 inch HD monitor TV, DVD and VCR...
My screen has one line going across the middle.
The problem is a vertical deflection issue, caused by bad connections on the vertical deflection ic, or needs to be replaced and one or two bad capacitors.
Mar 17, 2011 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Horizontal hold troubleshooting. Can hear but pic is like a line on the screen. Tried adjustments on back
If the line is half way up the picture. This is a vertical problem. Most likely the vertical output IC or a bad solder joint near the IC.
Jan 26, 2011 | RCA 27F501TDV 27 in. TV/VCR/DVD Combo
Hi i can connect my ps3 to my tv 25vt-k100 what
You sure can, all you need is the RCA cables. it may not work very good but it shouldn't stop you from connecting it to the Sharp 25VT.
Just make sure you still have the Yellow/Red and White cable that came with the PS3, if you lost it or missed placed it, I am sure you can find one cheap on-line or any local electronic/video game store.
I couldn't find out if you have the RCA connections on the TV but from the pictures I found it looks like you have them in the front and it may only be the Yellow and white ones, but that should still work
Apr 14, 2010 | Sharp 25VT-K100 Combo
My tv has only a line of couler in the middle of the screen going across it what is the problem and how do i easily solve it?
This is a failure of the vertical circuit. Usually this is either poor connections at the vertical IC or a defective IC. If you can solder, try resoldering the pins of the IC. If that fails to resolve the problem, replace the IC.
Keep me posted.
Dan
Feb 16, 2009 | Panasonic PV-DF2700 27 in. TV/VCR/DVD...
When turned on only gets a straight line of color in middle of screen
You lost your vertical sweep. most likely the vertical output IC or a power supply source is the problem.
Jun 07, 2008 | Panasonic PV-DF2700 27 in. TV/VCR/DVD...
25VT-K100 Tamperproof
try unplougging the tv and then put it back in again
Jun 02, 2008 | Sharp 25VT-K100 Combo
No remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
Televison & Video Logo
137 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
