I can,t reset the convergence on my tv, what next, thanks
    Novelist:
    Champion:
  • 203 Answers
Time to call a repairman, unless you can solder and use a meter. What brand and model are we talking about? Most convergence rapirs cost $300-$500 on average. Let me know if I can assist you furthur.
Tim
Posted on Sep 11, 2008
Sony kp-57hw40 double picture. regular and the other right next to it is red. tried auto focus and nothing happens. while holding auto focus btton down get red cross and white next to it. tv is 9 years...
Auto Focus button no longer work.Tv have a problems known as a convergence problems,it dead.Tv have colors lnes R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergnce board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 13, 2010 | Sony KP-57HW40 57" Rear Projection...
Panasonic pt-53tw53g projection tv,convergence problems -green hill on bottom.i replaced the convergence board with no luck,whats next?
Did you replace the entire convergence board?
With the information you are giving us, we can suggest to check the voltages from the power supply going to the convergence board. Double check the connectors that connect to the convergence board as well.
Oct 17, 2008 | Washing Machines
Replaced both STK392-120 still Blue Convergence problem
Hi, first. thing to do is go into "menu" and keep scrolling down until you get to convergence adjustments see if red & blue move up/down and also left/right, IF they dont you have a bad resistor(s) or open chemical fuse(s), if both colors move, scroll to "factory reset" and try re-setting, let me know the results, hopefully you did NOT.. use generic 120`s, video-tek
Feb 07, 2009 | Philips 60PP9202 60" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
Picture distorted and blurry with color
bad convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Convergence
have you replace the convergence IC's?
Dec 03, 2007 | Mitsubishi WS-55613 55" Rear Projection...
TV won't power up
Generally,first step is locate open pico fuse(s) in power supply,usually feeds convergence amps. Next,replace STK devices.Then,reset alignment in servicer mode.
Oct 02, 2007 | Mitsubishi WS-55807 TV
Tv won't turn on
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part number AA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
Jul 22, 2007 | Samsung HCM4215W 42" Rear Projection...
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
