Question about Sony God of War: Chains of Olympus for PSP
Speakers My speakers didn't made sound.
    Problem Solver:
  • 4 Answers
Probably your speakers are on mute.
Posted on Dec 28, 2008
    Problem Solver:
  • 16 Answers
Turn off avls
Posted on Sep 12, 2008
I have a 2007 trailblazer. The rear speakers didn't work and some of the head unit lights didn't work. I replaced the headed unit and that didn't fix it. I then replaced both speakers and one...
Put new wireing in going to both back speakers, Factory wireing is verry thin end it breaks with age. Change it over to at least 16 guage speaker wire or 12 guage, Your system will sound a lot better.
Oct 26, 2012 | Cars & Trucks
Altec lansing 221 computer speakers sound solution
Unfortunately it looks like Altec Lansing goofed up on this set and didn't provide a bass control knob. You will need to use some sort of software equalizer on your computer to turn the bass down.
Mar 24, 2012 | Altec Lansing 221 Computer Speakers
No sound on video
you didn't mentioned where you cannot hear the sound, is it when you play on the camera itself or is it when you play on your computer.
on your computer- it is possible you are missing the correct codec- you can try this website: http://www.codecguide.com/download_kl.htm
if it is on your camera- you didn't mention which camera you have- are you sure there is a speaker on the camera itself?
Dec 15, 2011 | Cameras
My pc left speaker didn't work. no sounds.
If one speaker doesn't work, then I would check the audio with another set of speakers. It could also be the sound balance that is turned all the way to the right. You can change the volume and balance in the control panel and sounds icon.
Jul 09, 2011 | Computers & Internet
My TV has a faulty audio input so DVDs have no sound Does the Samsung 1080P Home Theater System use its own speakers INSTEAD of the TV seakers ?
All Home Theater Systems (HTS) have/use their own speakers. If it didn't have speakers it wouldn't be an HTS . . . it would simply be a DVD player ;)
I can't give you any specific information about the Samsung HTS as you didn't supply a model number. 1080P is the output resolution, i.e 1080 lines, Progressive scan (= HD), not the model number.
Hope this helps.
Regards, BElectric
Jul 03, 2011 | Samsung Audio Players & Recorders
After unplugging my computer for a week, the sound on my CLT 190 LX computer monitor didn't work, even though I tried several sound sources from online as well as MP3s on my computer. The headphone...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
May 10, 2011 | Computers & Internet
Can't them to work on my tv after plugging them into the 3.5mm audio out jack
Excuse me if I'm sounding a bit dumb, but don't these speakers need to be powered by an external power supply (You didn't give the model but I'm almost 100% sure they do). if so are they connected to power? And if they are (again, you didn't give the make and model of your TV) are you sure it's an output and not an input jack?
Simple things of course but sometimes overlooked.
Regards,
Mikeywaf
Apr 21, 2011 | Insignia 2.1 Speaker System (3-Piece)
No sound from speakers on a dell dimension 3000
click volume bottom right desck top.
open volume control and make sure nothing is checked in the mute boxes.
Dec 04, 2008 | Manhattan 1100 Computer Speakers
Only a steady pulse comes out of my bull power
hello, it seems that you may have a bad ground on your amp? turn everything off(pull amp fuse at battery) and go to the amp ground and clean paint away to bare metal! secure ground tight and make sure the car battery is not low voltage! this may stop the pulse! the sound problem of no sound in speakers, if still there! make sure the speakers are not shorts or pinched to ground! this could damage the amp! hope this helps, good luck!
Jun 12, 2017 | Magnat Bull Power Reflex 300 Car Subwoofer
Sony God of War: Chains of Olympus for PSP Logo
42 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
