Question about Hitachi 61SWX01W 61" Rear Projection Television
Picture Brightness of picture has faded to near black over past 2 weeks. Do I need a new crt or what other part? (And best place to order on internet) Thanks in advance. -Joe B
  • traveler253 Sep 11, 2008
    Thanks! I suspected that and was afraid of being correct. Rather pricey parts, but think I saw them for around $175 each on one parts site. Thanks again Chris07551 !!
Can i replace the bulb myself. i'm pretty good with electronics
Posted on Sep 12, 2009
    Master:
  • 726 Answers
Ok ill have a look and ill get back to you in a few mins
Posted on Sep 11, 2008
  • chris07551 Sep 11, 2008
    ok the brand of your tv you can call buy phone and order parts and you can go on the net say if you tv is Toshiba go to www.Toshiba.com
    i really think the bulbs need replacing if the pic has done that there are three liquid filled bulbs inside roughly 250 dollars each and then you have to take the old ones out put the new ones in and adjust them it can be difficult
Philips 60PW9383 picture faded. Try to adjust, sharpness, contrast & brightness are all almost all of the way up, but the picture just looks weak & washed out.
Thats the classis sign that the CRT coolant needs replacement to restore the picture quality. You can get the Phillips CRT coolant kit from www.tvrepairworld.com which contains the coolant for the three CRTs plus the CD with instructions.
Jun 19, 2010 | Philips 60PW9383 60" Rear Projection...
Tv says fan 2 going out ! Picture is starting to fad away!
If the picture faded away on the order of 10-20 seconds (and if it comes back, also comes up to full brightness in same time frame - possibly with the persuasion of some careful whacking) AND with NO other significant changes such as size, focus, etc., then take a look in the back of the tube for the filament to be lit - the orange glow near the CRT socket. If there is none, then you probably have a bad solder connection on the circuit board on the neck of the CRT. Look for fine cracks around pins on that board. Try prodding it with an insulating stick to see if the picture comes back. Resolder if necessary. Dirty or corroded CRT pins/socket contacts can also do this - remove, inspect, clean, and replace the neck board. It is probably not a bad CRT as the filaments are usually wired in parallel and all would not likely go bad at the same time.
However, if only a single color fades in and out, then a bad connection inside the CRT is a distinct possibility - look for only one of the filament's glow to be coming and going. This is probably not worth fixing.
If the picture faded away with other symptoms, then there is probably a fault in the video amplifier/output one of its power supplies - still probably a loose connection if you are able to get it back by whacking.
Good luck
May 26, 2010 | Televison & Video
No picture on RCA.
prob bad connection crt filiment  socket could be loose on crt.
Dec 01, 2008 | Televison & Video
Brightness
Is the contrast setting normal? You tube 'may' be fading, but not yet failed. A licensed pro should help you decide whether a replacement is in order or not.
Aug 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture images getting dimmer or fading like no backlights
Hiii...
I'm not quietly sure ...have you check the GK Board looks at B+(135 V) check all 5V regulated..check all High voltage capacitor if there's have low ESR or dry cap...
# send me an e-mail to : be_cek@yahoo.com for compplete copy of the schematic...
Thank's
[Vrya]
Mar 04, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Mitsubishi VS-6041- picture brightness not very bright
Hi Dawn,
The TV does have a screen control on each of the picture tubes ( there are 3 ) although I do suggest you have a qualified technician make the necessary adjustments as an improper adjustment can cause damage to the set. Should you deside to make these adjustments yourself, you'll need to remove the back ( or front in some sets) ( PRE-CAUTION, UNPLUG THE SET FROM THE WALL BEFORE PREFORMING ANY ADJUSTMENTS INSIDE THE SET ) The screen adjustments are located either on the bottom of each tube or in a group component located where the main High Voltage Wire ( large red wire from the black transformer on the deflection board ) is connected to. Look for a turn pot ( screw type adjustment ) that is marked SCREEN. When you locate it ( whether it be on each tube or in the group component ) turn it up only slightly and not to much, as excessive gain ( turning it up to much ) may cause the TV to shut down. When you have the proper brightness ( when it looks good to you ) close the set up and enjoy the renewed picture. Good luck and I do hope this has helped in some way
Ed
NC Electronics
Mills, Wyoming
Nov 18, 2007 | Mitsubishi VS-6041 60" Rear Projection...
RCA 32" TV - Model #32F531T - Faded to black
Isolate filament voltage from CRT,i.e. unplug Crt socket from pix tube.Measure filament voltage on CRT PCB.If present,suspect bad pix tube.If missing,solder any/all connects in filament circuit,meaning CRT board first then main PCB.
Aug 08, 2007 | RCA 32F531T 32" TV
Screen went full bright one day.
Hello, please check the 10uf/200V capacitor around flyback transformer. Best regards, Arpi
Jul 17, 2007 | JVC AV-27230 27" TV
Horizontal white lines on top of screen
try to adjust the screen control in the flyback transformer. good luck
May 04, 2007 | Panasonic CT-27G14 27" TV
Hitachi 61SWX01W 61" Rear Projection Television Logo
79 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
