Question about HP Color LaserJet 3500 Printer
How can I print the label from tray 2?
I placed some labels on tray 2 but the print out only coming from tray 1.
  • Anonymous Sep 30, 2008
    I am trying to make my default tray 2 rather than tray 1
    Please help!
  • HP Master
  • 2,794 Answers
Go to the control panel.  Select printers.  Move the mouse to your printer.  Press the right mouse button and select properties.  press the advance properties button.  Select the tray you wish to print from.  press when finished.
Posted on Sep 11, 2008
I cannot retrieve FABRIC from inside machine. I was printing labels and now one is rolled around the roller inside.
About 1,350,000 results (0.86 seconds) Search Results
    [PDF]How To remove a stuck label from the LabelWriter? 1. the ...
    global.dymo.com/.../cRydqiFncuah2s6Pf5DxrozTFs...
    DYMO Corporation1. the labelwriter. 2. ... The cover is now completely removed. 7. lift up the innerguidance ... Make sure the rubber transport roller ... under the stuck labels with the cutter ... the front is completely in place. 31. Your LabelWriter is now ready to print.
    [PDF]Instructions & Troubleshooting - Pelikan Artline
    www.pelikanartline.co.nz/images/.../5InstructionsTroubleshooting.pdf
    Page 1 ... E Labels. F Platen Release Knob. G Ink Roller Loading Catch. H PrintHead. I String. Lift off the ... Determine whether the label roll is the ... on the roller inside the label ... Label Loading is now complete ... Index Bands all around.
    [PDF]Label Path Diagram - Primera
Jan 18, 2016 | Office Equipment & Supplies
How can i avoid label sheets getting stuck in phaser 8560
1. Make sure you are feeding the labels from the bypass tray, not from the cassette.-
2. Make sure the labels are for Laser printers, not Inkjet printers.
3. Do not try and re-use a label sheet that only was half printed on.
4. When you put the labels in the bypass tray, set the paper type to labels...this slows down the print process so they won't get jammed.
Jun 02, 2014 | Xerox Phaser 8550DP Printer
LABEL PRINTING
you might try downloading a template from avery.com that is what I use.
Mar 12, 2013 | Office Equipment & Supplies
How do I feed an AVERY label 5453 into the printer?
Just place the sheet of labels in the paper tray.
You may need to place the labels face down in the paper tray so the prints on the correct side of the labels. If it didn't print on the correct side of the labels then place the labels face up.
Jan 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
My new hp 2035n printer give an error when i try to print. the error says: load paper to tray 1
Instructions Things You'll Need:
  • Inkjet printer
  • Labels
  1. 1
    Prepare your printer. Make sure the power is on and the drivers are installed correctly on your computer.
  2. 2
    Wait for printer to stop. Make sure your printer is idle or ready or waiting for paper to be loaded. Don't load labels when your printer is already printing or running an operation.
  3. 3
    Prepare your labels. Make sure they are all facing the same way and are right side up. The label side should be face up. Many labels have an up and a down as well, look for a "this side up" or "load this way" indicator. Or take a look at the print preview before you print and make sure your labels will be fed correctly.
  4. 4
    Find the correct paper tray. Some printers have manual feeds and automatic feeds. Refer to your manual to find out which one you should use for labels. If you are going to use the manual feed, follow the manual's instructions. However, most printers will use the automatic feed, so read on.
  5. 5
    Align the paper guide. This is a moveable piece on the paper tray. There should be markers for the width of your paper. Standard pages are 8.5 inches. Move the marker so your labels will fit.
  6. 6
    Load your labels. Place your labels in the tray so it touches the immoveable side of the paper guide. Slide the paper guide over to touch the other side if it is not already close. Do not bend the labels by pushing in too far.
  7. 7
    Find the paper thickness lever. Try looking under the door that lets you change the cartridges. Or search around on the back or side. Check your manual, too.
  8. 8
    Set your paper thickness level. Usually you'll use the standard size. However, your printer may need to use a thicker setting. Check your manual.
  9. 9
    Change your media type. In your printer settings, find the media type option. You can access settings by clicking properties or settings on the print dialog right before you print. Select "labels."
Oct 02, 2010 | HP P2035N LaserJet Monochrome Printer
I have Samsung CLP/610 laser printer and need to
"MP tray" refers to the manual paper tray. This is the common setting for most word processors whenever printing media other than paper. This message will come not only for labels, but for transparencies, card stock, envelopes, etc. The reason for this is that the manual paper tray is designed to provide a straighter paper path that helps preventing your labels from peeling inside the unit. Therefore, I do not recommend placing them in the regular paper tray. Take note that you should also check that the labels purchased specify they are meant for laser printer or copier. Regular labels, or labels designed for inkjet printers will surely come off inside your printer and cause damage that the warranty will not cover.
Be blessed.
Apr 15, 2010 | Samsung CLP-500N Laser Printer
When I print labels the sheet is smudged using Dell 3110cn.
Due to the thickness of label stock it can take more heat to fuse the toner than when you use normal paper.
1 You MUST use labels that are suitable for laser printers.
2 When printing on labels, you'll probably put them (face down) in the MPF 'tray' in the door, and make sure you choose Label as your paper type under Printing Preferences, Paper Tray, MPF Settings
Mar 05, 2010 | Dell 3110cn Laser Printer
When printing it will not print from tray 2 it wants to print from tray 1 and is asking for labels. Then causing users to have to press the green check twice to change the option to print from tray 2. How...
Ok remove tray 2, and in back its got a little clicking adjustable lever that you need to move so it lines up with letter 8.5 x 11...this worked for me
Nov 27, 2009 | HP LaserJet 4700 Printer
Paper jam I tried to print some labels and the label paper is stuck in printer
1.When ever you place papers in the paper tray use fine papers which are not having any folds.
2.Keeps the papers correctly in the tray.
To Remove the stuck paper press the "START" button and hold it for some time. The torn paper will come out automatically. If the paper has not come out completely give the printer for service and get the paper removed completely.
Aug 31, 2009 | Office Equipment & Supplies
Problem with printing from Tray 1
It can be set from more then one place. In MS Word you would go into the tools setting then choose the envelope drop down, select labels and in the options for the label you choose the format as an Avery Equivalent. That is where you can tell MS Word which tray to pull from. Also in the printer properties, under advanced options you can designate what type of paper is in each tray. Good Luck
Jul 23, 2009 | HP LaserJet 4600dn Color Printer
HP Color LaserJet 3500 Printer Logo
69 people viewed this question
Seeker5211
Seeker5211
