Question about Toshiba Satellite 2415-S205 Notebook
Installing RAM today i bought 2 identical ram for my toshiba laptop increasing it to 2..now when i restart the computer it has an aqua screen and lines going vertically across the screen
    Scholar:
  • 97 Answers
You might want to try and remove the ram that you just installed and check if the problem is still the same. If it is then it's not the ram that's causing the problem. But if the problem goes away when you remove the newly added ram then you probably have a busted RAM
Posted on Sep 17, 2008
Operating system can't load because kernel missing or contains errors windows 8 toshiba laptop
cupl things you could phyical dump by pulling out batt and power then hold down power button for 40 sec if that dont work try removing ram 1 at a time if that dont work try a reinstall of windows
Jul 30, 2014 | Toshiba Satellite Computers & Internet
Is there a way the memory in a toshiba satellite 1005-s157 be increased to more than 512MB?
Yes you can, at least to 1 Gb maybe possibly to 2 Gb.
There will be two memory slots in your laptop. To increase the RAM to 1 Gb install another 512 Mb RAM module in the empty 2nd memory slot. Make sure you use the same make and speed RAM as the one that is installed.
If you have two 256 Mb RAM modules installed in your laptop then you need to replace the two 256 Mb RAM modules with two 512 Mb RAM modules to get a total of 1 Gb RAM.
Aug 04, 2012 | Toshiba Computers & Internet
Iv got a toshiba satellite A300 and i was wondering how can i speed my my graphics card ( in any way ) whenever i try to install games and play they there is always a fault of some sort one fault that...
When you will increase the ram your laptop will be fast soon.
You can increase 4 GB maximum.
For dissemble follow bellow the link
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A355-A355D/laptop-disassembly-1.htm
Maximize your Toshiba Satellite A300-ST6511 mobile computing power and add more memory. Trust PRO Memory Upgrade to provide dependable expansion options for your laptop or notebook with a Toshiba Satellite Small Outline DIMM RAM upgrade.
  • Your Toshiba Satellite maximum RAM capacity: 4GB
  • The Satellite A300-ST6511 has 2 memory slots or sockets
  • This Satellite module upgrade PIN count is: 200-PIN
  • The memory speed is: DDR2 800MHz, PC2-6400
  • The DIMM type for your Satellite A300-ST6511 is: SODIMM, SO-DIMM, Small Outline DIMM
  • For4 diassamble the
Hope it help you.
Jan 08, 2011 | Toshiba Satellite A300-ST6511 Notebook
My asus eee 900 pc with 512mb of ram, i upgraded to 2gb of ram, and it restarted fine, now with either ram chip in it it will start to boot up, but the screen stays blank and it attempts to start up with a...
request you to check speed of 2 gb ram with old 512 gb, if u r using 2 strrips of 1-1 gb then first remove both and resinstall old 512 again, and checked, again install both 2 gb ram and check. if after installation of 2 gb ram laptop is not restarting the problem is only with speed of ram. u may need to install ram with proper matching speed
May 26, 2009 | ASUS Eee PC 900 PC Notebook
Crash with ram
you need to remove that the new ram
too much for the system
then restart
Jan 21, 2009 | R.A.M. Computers Aqua Computer Aquagra FX...
Install ram
Is it an upgrade of RAM? If so, remove the new RAM and test the default RAM if you still have the problem. If the problem is solved, just reseat the RAM or better yet, remove the old RAM then just put in the new RAM just to identify which causes the problem.
Hope this helps.
Sep 16, 2008 | Toshiba Satellite 2415-S205 Notebook
It doesnt run
Try removing the RAm modules Carefully and clean them with a pencil eraser preferably the number 2 pencils may have been exposed to humidity heat or static this usally removes it if not and you can open the BIOS check wether the hardick drive is disabled enable this then reboot make sure the battery and all power is off when removing RAM modules
May 31, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba a105-s101 memory install boot issue
Check your owners manual to see if the laptop will support 2GB of ram. If not you will need to use 2 512mb sticks to get to 1 GB
BPCS
Dec 27, 2007 | Toshiba Satellite A105 Notebook
Toshiba Satellite 2415-S205 Notebook Logo
135 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
