Question about Whirlpool Kitchen Ranges
WHIRLPOOL OVEN PROBLEM. MODEL AKG 667 MODEL NUMBER NUMBER 8535 6671 5000 HOB IS FUNCTIONING OK, HOWEVER WHEN I SWITCH ON EITHER THE GRILL OR OVEN IT CONTINUALLY BLOWS THE FUSE
3 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: I HAVE A WHIRLPOOL GAS
hi thanks for the question so the igniter works but no gas most of the gas stoves have the same problem if the igniter works but no gas could still be the igniter the igniter must get almost white hot to ignite the gas if id does not the gas wont lite so the ather problem is igniter lights but no gas problem is with the 2 coils on the gas valve replace those thanks the appliance doc
Posted on Sep 17, 2008
Richie_asg1
  • 1036 Answers
SOURCE: GAS JETS BLOCKED IN OVEN
If there is only enough gas for the pilot, it is very likely the main gas ciontrol valve is either in need of replacement or the "hot wire" sensor is in the wrong place or broken.
Basically the hot wire determines if the pilot is lit before turning on the main gas supply valve. It is a safety feature to dissapoint the suicidal.
I suggest this is fitted by a gas engineer as a leak at the valve can be very dangerous.
Posted on Feb 09, 2010
No power at all :(
Sounds like either you tripped the 220 breaker in your household electric panel, or a fuse located on the oven's control board. (service man)
Jan 31, 2014 | Whirlpool AKZ159IX Oven
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
I have a belling 335 and both the oven and rear left hob ring have stopped working. what is likely to be the problem?
The thermal fuse inside rear is faulty. The grill also has it's own thermal fuse so make sure you change the correct one.
Sep 06, 2012 | Belling 335 Electric Kitchen Range
MY STOVES COOKER'S OVEN AND GRILL HAS STOPPED WORKING?THE HOB IS WORKING FINE.
The hob is normally totally independent of the oven. What is actually working or not working on the oven? i.e. does the grill still work, is the clock OK and can you set it, or is everything totally dead?
Oct 16, 2010 | Stoves 720EF Electric Double Oven
I have replaced a Kelvinator hob with a ceramic hob. It works but the owen is not working. What is the problem?
There are possibly a number of options. It could be that in wiring the hob in you have disturbed the wiring for the oven. Normally the oven works off the main oven control switch on the panel and the hob could be wired into something else.
Is the oven totally dead no power at all for everything, or is the clock running but the oven will not switch on?
Dec 29, 2009 | Stoves 720EF Electric Double Oven
Russell hobbs microwave will not work, but grill & oven ok.
The magnetron has failed. This is the part of the oven which produces the microwaves and they can fail without warning at any time after they leave the factory. Failures are not as common as they once were, but unless the oven still qualifies for a warranty repair it's always more cost effective to scrap the oven and buy a new or used replacement.
In your case, you may be able to recoup some money by selling your oven purely as an electric fan oven with grill. The magnetron failure does not in any way indicate that the grill or fan oven are about to fail.
If you do decide to replace the magnetron, make sure that a new microwave gasket is fitted as well; this is a small wire mesh doughnut (US= donut) which fits around the neck of the magnetron and is crushed into place when fitted. Once used they cannot safely be re-used.
Jul 21, 2009 | Russell Hobbs 10617 Glass 2-Slice Toaster
I HAVE A WHIRLPOOL GAS OVEN AND GRILL AKG667 MODEL NUMBER 853566715000 WHEN THE GRILL OR OVEN ARE SWITCHED ON THE FUSE CONTINUALLY BLEW. I CHECKED THAT THE CONNECTIONS WERE OK. NOW WHEN THE...
Sep 17, 2008 | Whirlpool Kitchen Ranges
Oven does not work
its just your heater element you will need to wright down your model number and go on ebay or go to your local appliance shop they might order you 1 there about £35 pound
Jan 07, 2008 | Ovens
The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Jul 20, 2007 | Stoves 800DFDOm Dual Fuel (Electric and...
Kitchen Ranges Logo
81 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
