Have HP WinXP PC. My Iriver H10 20GB is not recognized by the machine. Win XP is version 5.1 (Build2600.xpclient.010817-1148) The Installation CD has only Windows Media Player 10 but no driver. Earlier, I had installed the same Iriver with my laptop (IBM, WinXP) and had no problems in the system recognizing the drive. Would be obliged to get an expert opinion on whether there is a driver that can be installed to get my system to recognize.
You could also do the "emergency connection" trick. First, plug the USB into your computer, hold down the "o" button and push the reset button with something that has a point. The computer will recognize your h10 as a hard drive. The you can sync music to your player or just drag-n-drop it. you'll probably need to use a program like "Easy H10" to update your player's database. It's easy to use and it only takes a couple of minutes to update.
Go to this site as I did and I saw all sorts of firmware and drivers and support for your unit. Good Luck. http://www.iriveramerica.com
Throw your iriver h10 away because it is a piece of junk. this same problem happened to me four days after I got it.
It free up
Get a hammer and smash the dam thing and go out and buy a ipod. you'll be much happier
SOURCE: iRiver Music Manger not recognizing iRiver player when connected
OK, this problem was driving me almost to tears with frustration but have managed to bodge-solve it so hope this helps!
Right click My computer and select Properties.
Click on Hardware tab.
Click on Device Manager.
Hopefully there is a yellow question mark symbol against Iriver T30 listed under other devices or portable devices or something.
Right click this then select Update Driver.
Tell it that you are going to manually update the driver yourself.
Eventually you will have to select what type of device it is - select portable device.
Now click on MTP device and click next to install the driver.
Hopefully now it is recognised by XP in My Computer....
Good luck
H
SOURCE: Vista will not recognize iRiver H10 MP3 player
Try plugging in usb with the H10 turned off. Now, press the select button (with the round symbol on it) while turning the H10 on. This starts the player in 'emergency mode' and should be recognized by XP
SOURCE: Windows XP does not recognize my USB connected
I've Had the same problem.
Try unplugging the usb from the computer and putting it back in.
When I pug my iRiver H10 into my computer, it doesn't come up in "my computer"
Need an installation disc for an H 10. Have the player, charger, etc. no driver on my PC. rh
Same here! Iriver H10 -- recognized new hardware when plugged into laptop USB port, but do nothing when plugger into PC system which both operating Windows XP and with Media player 10. How strange! ?? :-/
its says that we should connect h10 iriver to iriver somthing
