Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive Logo
Kevin Martin Posted on Sep 02, 2011
The alternator light on my 2006 1.3cdti Combo has just started flashing slowly while the engine is running. Battery leads are secure and drive belt for alternator is ok. Any ideas welcome
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Feb 09, 2010
SOURCE: vauxhall combo epic 1.7 Y(01) battery light
the yellow relay is a red herring,its the glow plug relay just clicking as the current is trying to find another path to earth,id say its a dodgy regulator on alternator, but possible the light goe through the time circuit of the relan start up but id suspect regulator,
1helpful
2006 Holden rodeo have replaced alternator but battery still won't charge, brake light and battery light on dash come on but go off on 3000. Both battery and alternator are new. Any ideas thanks!!!
Hi Andy Well Normally if you have to get it to 3000 rpm to get lights out and start to charge I would have said faulty alternator. If your sure alternator is ok I would check the pulley belts are not slipping ignition off key out grab belts and give a hard tug on belts is there any slackness or abnormal movement (possible broken mount or bracket). If all good remove belts and make sure all pulleys that the belts run on turn freely and none are seized or sticking. If all good grab a set of jump leads connect the black earth cable to a good known earth on the engine and the other end to the negative earth terminal on the battery make sure both connections are clean and secure. Start vehicle has fault gone? if yes faulty earth connection between engine and chassis locate and repair as required. Fault still apparent check power side make sure all connections are clean & secure . wiggle test at battery terminals (all connections) Check at alternator starter motor is there any discoloured wiring (over heating) wiggle test all connections. Before wiggle test make sure you are able to disconnect the battery earth terminal quickly if required. Remove it 1st as a test run but make sure it is secured when testing. If all the above fails to rectify the fault get it to a Holden dealer as more in depth testing will be required Good luck
Battery light comes on while driving. Immediately after water pump/timing belt replacement. Replaced battery and alternator tests good. Intermittent battery light remains?
It sounds as though the belt may be slipping or is not tight enough?
If it's a toothed belt it won't slip - it may not be tensioned enough where it goes around the alternator pulley. They are adjustable.
A smooth non-toothed belt can slip.
Also, check the tightness of the battery leads where they connect to the battery and to the earth - on the bodywork/engine block
I was driving at night the lights slowly dimmed as the gauge slowly fell got so bad i had to stop as the motor starting revivng as i stopped the anti lock light cam on as then i had no lights as it idled i...
its either the alternator has give out. or a loose or broken belt. if belt is ok and tight, then at battery there should be at least 13 volts when engine is off. when running, at battery should read 14 to 14.2 volts. if lower than 14 volts while running, replace or rebuild alternator. have a good day !!
2helpful
Why is my charging light coming on at 2000 revs
There seems to be a no charge state in this case. I recommend checking the charging system. use the procedure below to isolate this issue.
Wear protective eye wear and clothing and remove all jewelry when checking your battery and charging system. Jewelry is a good conductor of electricity and is not recommended. Most batteries wear out every 3 to 5 years and need to be replaced. Always replace your battery with an equal replacement battery to assure proper operation. Automotive batteries have a +positive terminal (red), - negative terminal (black). Electricity is stored in the battery and then supplied to the vehicle when the engine is not running. While the engine is running the vehicles alternator charges the battery for future use. (Note: never disconnect the battery while the engine is running. If the battery cable is disconnected from the battery a spark can be generated which can cause the battery to explode or a major electrical malfunction to occur.)
To check a battery surface voltage, remove the positive terminal protective cover. Connect the +positive side meter lead (red) to the positive side battery terminal. Connect the - negative (black) side meter lead to the negative battery terminal. With the vehicle not running and the car sitting over night the battery voltage should be between 12.5 and 12.8 volts.(You will need to use a voltmeter for this testing procedure)
The alternator is rotated by a drive belt driven by the vehicles engine while it is running. Electrical voltage and amperage are generated to recharge the battery and supply voltage to the electrical system of the car. The alternator is held in place with mounting bolts. There is a main electrical wire on the rear of the alternator that supplies voltage to a main voltage junction box. If your alternator is not charging properly, your battery will slowly drain down from operating all the electrical systems in your car and stop the car from running.(most non charge states will be the cause of a loose belt or a low tension rate, due to a mis-adjusted alternator. make sure you have enough tension in the belt for full rotation of the alt pulley)
Next, you will need to check the alternators output with the Amp meter.
Testing the amperage output of the alternator is good for measuring the amount (not the level) of voltage the alternator can produce. This test can be tricky because if the alternator is weak it can still show it as producing amperage. Which is good, but if the voltage is low, it will still allow the battery to go dead. To check the amperage output of an alternator an amp meter is needed. Once the meter is connected start the engine. Next turn on all electrical accessories and raise the engine idle to about 1200 RPM. The alternator should output the max amperage it was designed to produce. Example: a 90 amp alternator should output about 88 amps. Note: An alternator cannot sustain maximum output for long periods of time. If the alternator is forced to operate at maximum output it will overheat and fail. An alternator is designed to operate at max amperage output only for a reasonable amount of time.
((Connect the voltage meter lead the same way you would in a battery static voltage check, Start engine (do not drive) at engine idle the voltage should be between 13.6 to 14.3 volts. If not the alternator may need replacing.)))
Starter, battery, or alter Promblems.
Additionally, If the above inspections prove that the charging system, and battery are ok, This will lead to a battery drain issue.
Here is a procedure I use to isolate a battery drain. Remove the negative battery cable from the battery. Using a 12-volt test light, hook one end to the negative battery post the other end to the negative battery cable you just disconnected. The test light will glow or "light" if there is a drain. If the "light or glow" is faint, that is probably normal draw for the clock or computer. If the "light or glow" is bright, this will indicate a large drain is present. That should be corrected,asap. Now start removing and replacing the fuses one by one until the light goes out; The one fuse that causes the light to shut off, will be the circuit with the drain. Remember to close the car doors, when testing. If not, the interior doom light will interfere with the results of the test.
New battery. left lights on & had to charge.
There seems to be a no charge state in this case. i recommend checking the charging system. use the procedure below to isolate this issue.
NOTE_ Ok, if everything checks out Ok with the above inspections, and you charging system is working correctly, this will lead to a battery drain issue. Use thsi procedure below to isolate the drain.
Here is the procedure I use to isolate a battery drain. Remove negative battery cable from the battery. Using a 12-volt test light, hook one end to the negative battery post the other end to the negative battery cable you just disconnected. The test light will glow or "light" if there is a drain. If the "light or glow" is faint, that is probably normal draw for the clock or computer. If the "light or glow" is bright, then there is a large drain. That should be corrected. Now start removing and replacing the fuses one by one until the light goes out; that one will be the circuit with the drain. Remember to hold in the button in the door jam for the interior lights.
1helpful
5answers
Battery not charging everything is good
1helpful
1996 SATURN 16 VALVE TWIN CAM BATTERY LIGHT CAME ON THEN TWO DAYS LATER WOULDN'T START
2helpful
2answers
1984 mercedes 300 diesel has no electrical power when running
Old Diesels do not require electricity once started so luckily the problem wont stop you once you're up and running, though if at night you wont have headlights, brake lights, hazzards or turnsignals.
Even if it was a dead battery, your alternator would still give you power once started.
I'll need more information to help diagnose better. First, once started, do you have electricity? Or is it dead all the time?
Alternators need the engine to spin them, so first make sure there is a belt attached to the alternator...open hood, look bottom left of engine for alternator...look to see if there is a black rubber belt attached to the pulley on front of alternator.
Then make sure wire cluster plug is plugged in securely to top of back of alternator. If so, follow the wires up to battery and see if they are torn, detached, worn or corroded.
You will need to a good new battery and to pick up a cheap voltage tester from Radio Shack or similar place. Check battery power, set voltage tester to 12V and with engine off voltage should be around 11-12V...once engine is started, it should be showing 13 to 14 volts.
There are lots of "bad" ways to check to see if alternator works, but they can damage the alternator's internal voltage regulator...so I warn you not to detach from battery while running.
If new battery is installed, connectors and all wires connected tightly, and still no power once engine is started...or you see voltage slowly dropping while engine is running...and turn on headlights...see if it still goes down lower...reach over top of engine with a friend holding tester leads to battery terminals, you can rev the engine...there is a metal bracket at top center of motor that will have a red sticker that says, "engine stop" pull it away from engine to rev, push to shut off engine...this a fuel control gadget. If you rev the engine and there is no change in voltage...and all wires are intact from alternator...then your alternator is not working properly and will need replaced.
I stress this, before you decide this is the prroblem (which is expensive and time consuming to fix, MAKE SURE ALL WIRES are SECURELY ATTACHED and in PLACE.
Please let me know if this helped you and if not, tell me what you learned and the other clues I need to better diagnose. Thanks and good luck!
WHILST DRIVIN MY MX5 SLOWLY LOST POWER !! PLEASE HELP ME !! MATT.
Well...your battery is dead. Check the connections of the cables on the battery posts to make sure they are tight and clean (no corrosion). While you're under the hood, look at the belt (serpentine) that runs your alternator. Is it there? If it fell off, your alternator can't charge your battery. You may have a bad alternator, a bad battery, or no belt....but use a battery charger to charge the battery...your alternator is only designed to "maintain" the charge, not bring it up to full power. Good luck, alternators for the MX5 are spendy, so I hope it's one of the other problems.
Top Enlight Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Enlight Computer and Internet Expert? Answer questions, earn points and help others
