Canonical Ltd. Ubuntu Logo
Anonymous Posted on Sep 11, 2008
Ubuntu AMD 64 Question
What is Ubuntu for AMD 64? Why do people run it? Is it any better (or worse) then the ordinary Ubuntu operating system?
Anonymous
Level 1:
  • Contributor 33 Answers
  • Posted on Sep 11, 2008
Anonymous
Contributor
Level 1:
Answers
33
Questions
0
Helped
7060
Points
85
Ubuntu for AMD 64 is the same as Ubuntu, only that it is optimized for use with a 64-bit processor, be it AMD or Intel. The upside in using Ubuntu 64 is that you will have increased performance when your ram is 4GB or greater because of the optimized architecture of 64bit. Any lower, you will not notice a difference between the two. The downside if it is that most softwares are made for 32bit, so your favorite app might not run on 64. If you are a newbie, I suggest you get the 32bit Ubuntu instead.
Have powespec G214. Has i7 but only one core is running. would like all
Ubuntu will NOT run on a muti-core motherboards properly. You should've just installed Windows 7 Ultimate 64-bit with SP1 or Puppy Linux Live.
HD booting in one PC but not in another
Ubuntu works with RAM and CPU Memory instead of a pc like xp that uses Virtual RAM. If the pc that could not load ubuntu doesn't have enough ram to support the reading of the Hard drive and the Operating System then it won't work and Xp will only run on the computer that xp was installed onto the hard drive.
Ubuntu is not starting...
Uninstall Ubuntu and try Ubuntu 32bit version.
Vista sometimes does not get along with other software,or O.S
1helpful
CANT INSTALL 64BIT PROGRAMS ACER ASPIRE 5100-3357 ATHLON AMD TURION 64 TECHNOLOGY 2 GHZ LAPTOP SYSTEM TYPE: 32-BIT OPERATING SYSTEM RUNNING WINDOWS VISTA HOME PREMIUM
64-BIT PROGRAMS runs on 64-BIT OPERATING SYSTEMS
The 64-BIT Processor has nothing to do with it, it serves a different purpose specifically, to the OPERATING SYSTEM.
Application Error
better uninstall the program and reinstall it..
Minimum System Requirements
Software
The 32-bit version of Autodesk 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft® Windows Vista® operating system
* Microsoft® Windows® XP Professional (SP2 or higher) operating system
The 64-bit version of 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft Windows Vista
* Microsoft Windows XP Professional x64
3ds Max 2009 30-day trial version requires the following browser:
* Microsoft® Internet Explorer® 6 or higher internet browser
3ds Max 2009 30-day trial version requires the following supplemental software:
* DirectX® 9.0c application programming interface (required)
* Some features of 3ds Max 2009 software are only enabled when used with graphics hardware that supports Shader Model 3.0 (Pixel Shader and Vertex Shader 3.0). Check with your manufacturer to determine if your hardware supports Shader Model 3.0.
Hardware
At a minimum, 3ds Max 2009 32-bit requires a system with:
* Intel® Pentium® 4 or AMD Athlon™ XP or higher processor
* 512 MB RAM (1 GB recommended)
* 500 MB swap space (2 GB recommended)
* Hardware-accelerated OpenGL® application programming interface and Direct3D® application programming interface supported
* Microsoft Windows – compliant pointing device (optimized for Microsoft IntelliMouse)
* DVD-ROM drive
Note: Apple® computers based on Intel processors and running Microsoft operating systems are not currently supported.
At a minimum, 3ds Max 2009 64-bit requires a system with:
* Intel EM64T, AMD Athlon 64 or higher, AMD Opteron™ processor
* 1 GB RAM (4 GB recommended)
* Hardware-accelerated OpenGL and Direct3D supported
* Microsoft Windows – compliant pointing device (optimized IntelliMouse)
* DVD-ROM drive
Amd turion x2 rm70 vs intel core 2 duo t5750!!!!
I read this and don't believe you - yes the AMD dual core gets hot - yes AMD processor are HOT processors - is intel better - no there on par with AMD - the thu put rate is so close it doesn't matter - now vista basic is just that BASIC - if you want to bump it up - home premium 32 or 64 but ultimate 64 should get it going.
1helpful
Flash player 9 on suse 10.1
NOTE: Since many proprietary video codecs, flash player etc.. are not available for 64-bit platforms, it is difficult to configure 64-bit machines for a complete multimedia experience. Hence it is advised that users new to linux use the 32-bit version of SUSE (32-bit SUSE works fine on 64-bit AMD machines)
Way to check would be open a terminal
type uname -a
If you use 32-bit Follow this page - http://tweakhound.com/linux/suse/101/installing_1.htm
I use ubuntu and to be able to compile flash you need dependencies to be met.
If you need more help, ask.
G'luck
2answers
E2180 Vs Athlon 64 X2 5000+
depends on what you plan to do with the cpu amd are good but a 3200 may only run @ 1.8 to 3.2 ghz depending while a intel 3200 will run 3.2 ghz.
I believe intel are more stable & run cooler than AMD but AMD benchmarks on Games better but run hotter (so get a good cooling fan & heatsink both pentium / celeron d & intel dou / dual core / core 2 dou and amd x2 have 2 cores (but watch your front side bus and cache the higher the better but the more $ also) then You need a good stable mobo that supports the chip you get (I preffer asus & msi for Gamers and biostar / msi for home users)
COREL x4 running very slow & spooler problem
System Requirements:
Processor:
# Pentium III, 800MHz or AMD Athlon XP
Operating System:
# Windows XP with Service Pack 2 or later
# Windows Vista (32-bit or 64-bit editions)
Hard Disk:
# 430 MB
Memory:
# 512 MB RAM
Optical Drive:
# DVD-ROM
Other:
# 1,024 × 768 or better monitor resolution
# Mouse or tablet
Where these are the minimum specs I would recommend at least 1+gb memory and a good graphics card and a P4 or AMD processor running at 1.8ghz or better, and that would depend on how in depth you get into the program
Top Canonical Ltd. Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
